Red Bull RB8 Renault
beelsebob
beelsebob
85
Re: Red Bull RB8 Renault
Hail22 wrote:
beelsebob wrote: Actually, they can, and did, a couple of years ago.
The Scottsman speaks the truth, that concept won't make it past the FIA checks before FP1, otherwise Sauber can have last years wing they used at Melbourne and Macca/Ferrari can have holes in their floors ;)
Just to clarify – I don't believe the air going under the bridge is feeding the diffuser, and hence don't believe it is illegal. I do believe that it's exiting above the floor again, the tunnel is just there to get it to merge nicely with the flow over the side pod.
bhall
bhall
244
That's perfectly legal, because it's the aperture for the pull rod.
(A brilliant interpretation, I might add.)
agungn51
LoudHoward wrote:Not sure if it's just the lighting, but is this what is happening here?
" Many inventors achieve great success, because they treat inventing like a serious busines - Inventing is often the easy part; the trick is to know what needs to be invented "
bhall
bhall
244
F@%$!!!!
Gentlemen, the 2012 FIA Formula One World Constructors' Champion.
Crucial_Xtreme
Crucial_Xtreme
404
I'm not sure where else you think the air can go? The air under the bridge is going to stay close to the coke bottle & go directly over top of the diffuser through & over the gurney flap. The exhaust looks like it's heading towards brake ducts/seal the sides.
bhall
bhall
244
It doesn't matter where that air goes, fellas. The hole is the aperture for the pull rod, and it's totally legit.
beelsebob
beelsebob
85
agungn51 wrote:Image
I disagree with where the exhaust is going:
Reason: Removed image quoted from post above
gandharva
252
Seems RBR is routing cold air besides the sidepod, through this small tunnel and than this air stream gets sealed by exhaust gases. Could somebody please explain the physical advantage of this sulution?
Timstr
Timstr
Slot closed here:
beelsebob
beelsebob
85
I have no idea why you guys think the exhaust is magically going to jump out of that channel and flow to the middle of the car... You don't think they designed it like that specifically to get it to flow off the edge of the side pod at all? Why would they not have a channel flowing down the side pod if that was where they wanted it to go ;)
Hail22
144
Possibly trying to find a way to compensate for losing EBD?
All i know is Webber isn't doing long stints as himself and vettel have been eating through the tyres.
Gilles Villeneuve
beelsebob
beelsebob
85
Timstr wrote:Slot closed here:
Optical illusion – that slot's open.
Hail22
144
[img]http://img3.auto-motor-und-sport.de/Red ... 90.jpg[img]
Bloody hell i got it! that slot is feeding the starter hole look at the gap in the hole then the slot which is blowing/sucking air through...convenient eh?
Gilles Villeneuve
bhall
bhall
244
Christ, that's the starter hole.
amouzouris
105
bhallg2k wrote:Christ, that's the starter hole.
indeed it is the starter hole but i think it is possible the air is directed in there..they did it last year as well
