McLaren MP4-30 Pre-launch Speculation
FrukostScones
163
Re: McLaren MP4-30 Pre-launch Speculation
this does not make a lot of sense to me . Why build a test hack now and be ready to use it only to run it next year when lessons learned from it cannot be transferred to the lunch spec of the Mp4-30....
this looks more like they have something else in mind :
http://www.rototest.com/dynamometer/dyn ... tor=1&DN=2
http://www.tdi-plc.com/racing-legends-arrive/
sure you need some serious fans to move enough air through the car but I don´t think this is something you cannot do ..so full racing simulations are possible -minus g force of course as the whole assembly will be stationary..so not quite the real deal but better than nothing and you may be able to decipher g-load influence on performance by using such a rig .Nothing really new here .
It does make sense. The Honda engine is one that comes late to the party and requires catching up. Nothing better than catching up by putting the engine in a chassis that is known. This makes it much easier to point out issues and make sure these aren't present in the new chassis.
FW17
171
Does anyone have a Santander red white livery for a Mclaren
Redragon
19
a still from Honda launch video I don't know if will give any useful info
https://www.dropbox.com/s/7vn8n4s9nrbwb ... 7.png?dl=0
FrukostScones
163
Has Mclaren already built a different gearbox and modified the MP4-29 monocoque? if yes, that means they spent a huge amount of money and that they are very swift. If no, that means the Honda PU has a Merc-like split turbo (because you can't mount a classic turbo in the original 2014 Gbox) and very simlar dimensions (compressor, Batteries etc)
Blackout wrote:Has Mclaren already built a different gearbox and modified the MP4-29 monocoque? if yes, that means they spent a huge amount of money and that they are very swift. If no, that means the Honda PU has a Merc-like split turbo (because you can't mount a classic turbo in the original 2014 Gbox) and very simlar dimensions (compressor, Batteries etc)
Highly probable Honda will have built upon the Mercedes PU. They'll of course have differences in order to squeeze more out of it, but if they can just run a modified mp4-29 it is already telling how little differs.
lotus7
lotus7
From what I understand, the mounting bolt dia and postions for both engine / monocoque and gearbox / engine are fixed dimensions per the FIA regs for all manufacturers . Does this not make basic engine and gearbox mountings "interchangeable" - excluding any ancilliaries ?
Quote: "5.3.5 Power unit mountings may only comprise six M12 studs for connection to the survival cell and six M12 studs for connection to the transmission. All studs must be used and may be fitted on the survival cell, power unit or transmission. The installed end of the studs must be M12 and the free end may be a different diameter.
The mounting faces of the studs for connection to the survival cell must lie on the forward of the two planes described in Article 5.3.4 and be located at Y215/Z15(2), Y340/Z260(2) and Y175/Z420(2).
The mounting faces of the studs for connection to the transmission must lie on one vertical plane normal to the car centre line and be located at Y100/Z15(2), Y150/Z140(2) and Y255/Z345(2).
A tolerance of +/- 0.2mm will be permitted on all of the above dimensions, all dimensions refer to the centre of the studs.
The distance between the two planes is fixed at 480mm (+/-0.2mm).
The Moderator
-1
will the team change the nose ? :(
Shrieker
The Moderator wrote:will the team change the nose ? :(
They have to. It does not comply with the 2015 nose regulations.
There is a render here, from the 2015 Noses merged thread, posted by a fellow member.
Oh how i wish...
-Atatürk
Egresi Tamás
Egresi Tamás
CjC
CjC
Egresi Tamás wrote:Anyone! Please! Premium post.
http://plus.autosport.com/premium/featu ... da-package
Haha, you couldn't write this...
Look in the MP4-29H thread, scarbs gives a rough outline of his article with the picture.
Just a fan's point of view
astracrazy
astracrazy
31
now peter is there, there will some red bull philosophy influence
What i am hoping for now that Peter is here and so much reshuffling has been done is that the 30 will be a simple, "clean" and highly efficient Racing Machine with no Gimmicks. So yeah, basically a Red Bull / Merc W05 type of Design Philosophy.
