Mercedes AMG F1 W08 EQ Power +
Juzh
161
Re: Mercedes AMG F1 W08 EQ Power +
Rules regarding fuel flow and max revs are intentionally written with lots of rev headway in mind. Primary reason for this is to avoid drs trains. I'd say the rules succeeded entirely in this aspect.
Extra large.
WaikeCU
Is this in Bahrain? Looks like a new fin to me. Looks way pointier towards the rear.
It is Bahrain.
dans79
267
It's definitely different compared to what Bottas ran in practice last week. The area to the uprer right of the Mercedes badge looks shrink wrapped.
197 104 103 7
atlantis
atlantis
21
That's two mini-wings in the chimney? :)
Far bigger cooling outlet for the chimney, and yes, it looks like two wings (well, more likely there as deflectors to balance flow front and rear out of the exit - but they'll still be airfoil shaped)
diego.liv
diego.liv
Looking at it from the side,it seems that the every holes are in line with the little bridges, that act as supports, inside the chimney: in Australia they covered something like 2 thirds of the chimney, so it's likely that they bolt in 1 or 2 pieces of cover when maximum exhaust isn't needed (i.e. Australia Image ), otherwise they leave it all open (i.e. Bahrain here)
I wonder how that shimney works and what it cools because normally, the air that enters the sidepods and the airbox cooling intakes isnt supposed to circulate freely there, but it's meant to go "straight" to the rear outlets, not to go upwards...
(that's why many cars had/have some kind of fence to prevent the air from going upwards*...
So the shimney is probably connected to a duct that is isolated from everything else and that cools something.. the rear oil rads?
theWPTformula
50
Freestream flow above will pull that little bit more hot air out. Gearbox oil radiator sits near the two nostrils in the engine cover (used since 2014). Better than further opening up the rear bodywork I imagine.
seezung
seezung
56
digitalrurouni
digitalrurouni
I love these pictures. I love the Bahrain spec shark wing on the Merc. And omg that Force India livery...that desperately needs to be brought back!
Via @AlbertFabrega
shady
shady
shady wrote:
06 Apr 2017, 17:26
what would stop them from making that flat piece, thats covering half of the opening in the shape of a aerofoil, with strakes underneath to help with the flow out of the car.. just seems like its missing detail.
Called it.
flickerf1
flickerf1
The Wicked + The Divine.
