Google Sketch Add ons
Post Mon May 28, 2012 3:41 pm
Sorry guys i didn't know if this is where i should post this but as most people seem to be using sketchup for the models in this forum i thought it is
Does anyone use any free additional addons to make there models? I'm using just the free version atm but didn't know if there was addons people are using as either aids or to make it better
astracrazy
Post Mon May 28, 2012 4:14 pm
The Pro version is out there and very easy to find.
2D Fillet: http://www.ohyeahcad.com/download/
Bezier Curves: http://sketchup.google.com/intl/en/down ... ripts.html
Also, loads of stuff on here worth checking out - http://sketchuptips.blogspot.co.uk/p/my-plugins.html
RicME85
Post Mon May 28, 2012 4:42 pm
I dont use plugins,
Budding F1 Engineer
N12ck
Post Mon May 28, 2012 10:59 pm
Only Plugins I ever use are the one for Kerkythea (For rendering), and I have another one to calculate volume for the fuel tank.
jordangp
Post Mon May 28, 2012 11:17 pm
jordangp wrote:Only Plugins I ever use are the one for Kerkythea (For rendering), and I have another one to calculate volume for the fuel tank.
Well other than kerkythea no Plugins at all
Budding F1 Engineer
N12ck
Post Tue May 29, 2012 12:51 am
I use Cloud_v6 so that I can import wing profiles easily and the whole fredo tools library including the fillet in 3d and others.
But I am generally bad at sketchup, coming over from solidworks is hard work
MemroableC
Post Tue May 29, 2012 9:06 am
thanks guys
what do you use to calculate fuel tank size?
astracrazy
Post Tue May 29, 2012 4:43 pm
astracrazy wrote:thanks guys
No idea, downloaded it a long time ago. I'm sure you can find it.
jordangp
Post Wed May 30, 2012 12:51 pm
MemroableC wrote:I use Cloud_v6 so that I can import wing profiles easily and the whole fredo tools library including the fillet in 3d and others.
I visited that forum thanks to this post, some fantastic plugins on there.
On my latest version of my car I have been trying to work in smaller areas to create nicer surfaces and this has meant that Ive had to do lots of laborious work joining lines, thankfully now I dont have to as the 'Skin' plugin will create a surface between two lines for you =D>
RicME85
Post Wed May 30, 2012 2:04 pm
RicME could you send me the link please?
Dan Cottrell
Master Of Innovation!
CottrellGP
Post Wed May 30, 2012 2:51 pm
I found it in the 'must have' thread - http://forums.sketchucation.com/viewtop ... 23&t=16909
You need to sign up to be able to see the download links.
Helpfully they have GIF's to show what the plugins can do.
RicME85
Post Wed Jun 06, 2012 7:12 pm
what settings do you guys use for Kerkythea?
astracrazy
Post Wed Jun 06, 2012 7:20 pm
depends how long I can be bothered to wait.
usually, if Im just uploading a batch of pics for an update post then I keep everything the same but change to 0.6 PhotonMap - Medium + AA 0.3
RicME85
Post Wed Jun 06, 2012 7:37 pm
RicME85 wrote:depends how long I can be bothered to wait.
For really high quality renders I can wait up to 3 hours :lol: but for quick batch uploads I wait about 10mins :D
Budding F1 Engineer
N12ck
Post Wed Jun 06, 2012 7:52 pm
tbh I havent messed with the settings much so dont know how the various options differ.
what do you use for your decent renders?
RicME85
Next
Return to Engineering projects
Who is online
Users browsing this forum: CCBot [Bot] and 1 guest
