What does a DD Diffuser look inside
CottrellGP
CottrellGP
I am building a 2010 F1 car and i don't understand how a double diffuser works and what it looks like inside i need some pictures or drawings to help me and to explain to me what it looks like inside and from below, all help will be appreciated.
Dan Cottrell
Master Of Innovation!
bhall
bhall
244
Re: What does a DD Diffuser look inside
(via Scarbs)
The double diffuser worked by routing air from below the car up to above the car - ideally using the beam wing to help drive the process. By doing this, you increase the mass flow of air below the floor. This increases downforce. In simple terms.
A good lot of pictures and discussion about the R30 double/triple diffuser here:
viewtopic.php?f=12&t=7659&start=615
PaulB
72
Red Bull RB6
Ferrari F2010
"Being second is to be the first of the ones who lose!" - Ayrton Senna
Paul Bischof
Milton Keynes, UK
MK2 2HL
http://paulsf1.wordpress.com/
CottrellGP
CottrellGP
Just_a_fan wrote:The double diffuser worked by routing air from below the car up to above the car - ideally using the beam wing to help drive the process. By doing this, you increase the mass flow of air below the floor. This increases downforce. In simple terms.
Thanks, a very good description which im sure will help me :D
Dan Cottrell
CottrellGP
CottrellGP
PaulB wrote:Red Bull RB6 ...
Thanks Paul im still slightly unsure what the pipes/ducting or what ever there called look like from inside the diffuser but im going to look a some more pictures aswell! thanks!
Dan Cottrell
I have 3 images of the Renault DDD
CottrellGP
CottrellGP
Can anyone help me with the dimensions of the holes in the floor for the ddd?
Dan Cottrell
MIKEY_!
wow soooooo much expansion in that renault diffuser, i never realised how big the DDDs got
