Need help: steering wheel/steering column connection point
firasf1dream
firasf1dream
hello guys,
i am building a steering wheel similar to F1 but please i need to know what is the name of these bases in red in the pictures and where can i buy one ?
here are the pictures :
firasf1dream
firasf1dream
Re: please help, where to find this wheel base ?
hello guys,
no replies ?!
bhall II
bhall II
473
If you can, change the title of the thread so that it asks about steering wheel connections. Wheel base, or wheelbase, typically refers to the distance between the front and rear wheels.
Re: Need help: steering wheel/steering column connection poi
I changed the title.
firasf1dream
firasf1dream
ok thanks a lot, you are right i didn't know what exact title to write
Salu123
Salu123
Kick
Sanjay13
I think what you are looking for is called a steering wheel quick release.
However I don't know what the mechanism in the right side of the 2nd image is used for. Hope it helps :)
lotus7
lotus7
While we are at it, does anybody have info on the steering column wiring loom , electronic connectors between steering wheel and column loom , of a F1 or similar car ' Lots of connections taking place when changing or fitting the steering wheel. Bluetooth or something similar ?
knabbel
The connection is standard CAN-Bus
lotus7
lotus7
knabbel wrote:The connection is standard CAN-Bus
Do you have details of the physical connection ?
firasf1dream
firasf1dream
Sanjay13 wrote:I think what you are looking for is called a steering wheel quick release.
http://www.sparcousa.com/sites/default/ ... p%2009.jpg
no not the quick release, i am looking for the mechanical system at the end of the column that will give me force while steering
firasf1dream
firasf1dream
lotus7 wrote:While we are at it, does anybody have info on the steering column wiring loom , electronic connectors between steering wheel and column loom , of a F1 or similar car ' Lots of connections taking place when changing or fitting the steering wheel. Bluetooth or something similar ?
no not bluetooth which i used to think it was first when i started to get into it 2 years ago, it's simply like a PS joystick, the wiring is by a circular connector something similar to these
https://www.google.com.lb/search?newwin ... -nChsLWCf4
The description mentions a "steering hub" or "steering hub adapter", and "steering column shaft". Perhaps it's that?!?
http://www.sparcousa.com/product/quick-release
Going back to your images, the top image most definitely is the hub. Concerning the second image however, the steering column shaft is the general term for the complete column assembly that gets connected to the steering wheel. There are all kinds of diagrams to find when you google "steering wheel column", so I think you'll get what you want that way.
knabbel
That is a force feedback servo motor.
You better use an existing force feedback steering wheel and modify that. Because except for the mechanical parts,k you also need alot of electronics and drivers to control it.
firasf1dream
firasf1dream
no i have my electronics system which i built, so i only need a spring system to make the steering wheel go back to the original position so it resist your hand force
