Never knew a windows desktop was such a serious piece of Formula 1, however he did have wind forcast/modelling for the circuit up earlier and may of seen me coming up to take a snap of his new work space
Hail22 wrote:Very serious business at Mclaren, look at Sam Michaels body language xD
kilcoo316 wrote:Hail22 wrote:Very serious business at Mclaren, look at Sam Michaels body language xD
Worst is... they are still using XP!
adrianjordan wrote:Don't get how that's worse?
kilcoo316 wrote:adrianjordan wrote:Don't get how that's worse?
The 2GB uninterrupted address space limit in XP means it can be very restrictive for engineering applications.
7 has far better networking and has better simultaneous processing capabilities.
I don't use XP anymore, while it did eventually become rock solid, it was also no longer fit for purpose for me, I couldn't live inside the memory limits, even with the PAE enabled.
raymondu999 wrote:Wouldn't you need 64-bit to use more than 3.3GB anyways? It's been a while since I stayed on the edge of hardware technological advancement though
Federico wrote:raymondu999 wrote:Wouldn't you need 64-bit to use more than 3.3GB anyways? It's been a while since I stayed on the edge of hardware technological advancement though
Nope. All the recent processors have PAE support, that means they can address more than 4GiB of ram even with a 32bit kernel.
taperoo2k wrote:Federico wrote:raymondu999 wrote:Wouldn't you need 64-bit to use more than 3.3GB anyways? It's been a while since I stayed on the edge of hardware technological advancement though
It's dependent on the Operating system, Microsoft routinely limits 32bit consumer OS's to 4gb even with PAE switched on. There are unofficial patches to get around that, but system stability is hit and miss (drivers tend to throw a wobbly).
myurr wrote:raymondu999 wrote:So Rob Smedley must be using XP then
Kaboom tish.
I'm guessing that McLaren might be running XP in a virtual environment on the pitwall, the benefit of that being you only need one computer/server to do it.
Compability in Windows 7 Ultimate/Enterprise is easy peasy - XP Mode. You can either run a virtual XP desktop or run it in the background. Just means you can use legacy apps without much trouble.
The MP4-27 looks like a nicely designed and packaged car so far. The titling wings look like another nifty design by McLaren.
Users browsing this forum: No registered users and 3 guests
