A paperboard Red Bull RB6 by PaulB
Post Wed Nov 03, 2010 5:25 pm
What are you up to Paul? Building your own RB6?
"Unbelievable how silly this Formula 1 is these days, with this stupid overtakes."
—Sebastian Vettel, 2012 US GP
Ignored Users: Cam, Traction, munudeges, Emerson.F
Diesel
Post Wed Nov 03, 2010 5:41 pm
Diesel wrote:What are you up to Paul? Building your own RB6?
Perfectly right. I scratch my own RB6 in 1:10 out of paperboard.
Look at this site: http://www.modellboard.net/index.php?topic=34017.0
"Being second is to be the first of the ones who lose!" - Ayrton Senna
Paul Bischof
8010 Graz
http://paulsf1.wordpress.com/
PaulB
Post Wed Nov 03, 2010 6:02 pm
All i can say is WOW. =D>
ecapox
Post Wed Nov 03, 2010 10:07 pm
Streewth! nice work! 8) =D>
The impossible often has a kind of integrity which the merely improbable lacks.
djos
Post Wed Nov 03, 2010 11:15 pm
WOW. You sir have a skill. I can't wait to see the finished article, what an amazing project! You should setup a blog to log your progress :)
Diesel
Post Thu Nov 04, 2010 1:58 pm
Wow! You must have a lot of patience Paul!
Very impressive work.
Perhaps you could create a thread somewhere on F1Technical to post pictures updates etc?
forty-two
Post Thu Nov 04, 2010 7:10 pm
Diesel wrote:You should setup a blog to log your progress :)
forty-two wrote:[...]
Sure i can. If you want to, i could create a thread somwhere in here. Let me know where i have to put it in. Off- Topics?
Paul Bischof
8010 Graz
PaulB
Post Tue Nov 09, 2010 5:44 pm
Hello Guys!
Now i have a big Problem. The shape of the front part cooling air intake is wrong. I don't know what exactly went wrong. But i think, that the shape of the lower section of the intake should be so narrow as it should be much earlier than the upper section. Now I'm a little bit helpless.
Here a few pictures:
By the way I made the two rear wing end plates. The two cans are interchanged, because the RB cola's writing on a can looks at the other side, than it looks at the RB6. But I don't care about that. Maybe nobody would have recognized this.
By paulbischof at 2010-11-09
Cheers
Paul
Paul Bischof
8010 Graz
PaulB
Post Sat Nov 13, 2010 12:28 pm
Now, i took the upper Section of the Underbody away, and put anew one at the car. Now i hope, that the shape of the side boxes will be correct.
I hope, later i don't see the grain from this action :| .
I also work a little bit at the rear wing. It's almost finished. Only the screws and the RB- Logo are missing.
I made the F-Duct Version past Hungary. The front wing is in the Silverstone version - that means, the car will be in the modus between Hungary an Japan.
Later the rear wing will stand on the diffuser.
Cheers,
Paul
Paul Bischof
8010 Graz
PaulB
Post Fri Nov 19, 2010 4:43 pm
Where is the fire extinuisher placed in a modern Formula 1 car (ecpesially the RB6)?
I have an assiciation, that it could be in the left side pod under the radiator.
In the right hand side pot is the ECU and in the left hand? Maybe the extinguisher.
Does somebody know anything about that?
Paul Bischof
8010 Graz
PaulB
Post Fri Nov 19, 2010 5:39 pm
I beleive extinguishers need to be mounted inside the cockpit area. Although I haven't seen the Red Bull position, they tend to be either mounted in the "V" under the drivers knees or to the side of the seat.
scarbs
Post Fri Nov 19, 2010 7:31 pm
I think Scarbs is correct.
FIA F1 tech. Regs wrote:14.1.7 All parts of the extinguishing system must be situated within the survival cell and all extinguishing equipment must withstand fire.
There is provision in the rules to have more then one extingusher bottle so placing
it at both sides of the seat would be possible.
While I can´t speak for F1, the position Scarbs mentioned (under the drivers knees in front of the seat) is very common/popular in single seater race cars.
that is the bottle/system in principle as used by BMW-Sauber some years ago.
- Colin Chapman
747heavy
Post Sat Nov 20, 2010 7:24 pm
A few new pictures of my RB6:
that's it for the moment
Paul Bischof
8010 Graz
PaulB
Post Sun Nov 21, 2010 4:11 am
great work Paul =D> =D> - very impressive
as for the fire extinguisher position, here a photo from a Honda.
I know, it does not help you directly, but I hope it helps to get
an idea of a possible shape and location.
- Colin Chapman
747heavy
Post Sun Nov 21, 2010 8:57 pm
WOW!!! Amazing job Paul =D> =D> =D> , I'm speechless to be honest with you now :shock: The details are breath-taking. I hope you will finish the work most successfully.
Next
Return to Off topic chat
Who is online
Users browsing this forum: CCBot [Bot] and 5 guests
