Honda F1 project leader Yusuke Hasegawa has outlined a number of reasons why Honda has been struggling so badly in the beginning of the 2017 Formula One season. He confirmed that lots of problems were not discovered while running on the dynamo meter.
damager21 wrote:Honda engine looks quite promising in speed traps during Australia race. Except in sector 2 where Button was 10 kph down on Hamilton, the other two sectors we were between 1 to 4 kph down. Bahrain will be a true test of progress made by Honda engine.
Honda had listened to Magneti Marelli's advice, and that the result was a much more progressive engine, having previously been reluctant to have dialogue with the Italian firm.
"It was very hard to get us to sit and talk with the people from Magneti Marelli to try to understand its electronics a bit better," an HRC source told Motorsport.com.
"Here, we do things our own way, which is usually considered the best way. But when that changes, you have to adapt to the new scenario. However, that's not easy at Honda."
Is there an actual pre-chamber, or are we really talking of typical current stratified charge strategies ?
made turbine-MGU-H-compressor complex bigger
overhaul/alteration to intake piping was needed and was challenge because bigger turbo-mgu-h complex in the V provides less space for inlet piping
seems Sakura's dyno facility has 10 dyno beds at least (not sure if the building is just 1 floor or 2 floors)
Nakamura (chief engineer)
sad/devastated about Alonso at Hungary Quali esp, it stuck in his mind and made him determined to overcome reliability and bounce back
Hasegwa
being one team and respect is important of course, but what's essential is to make competitive power unit
no matter how well you get along each other, it's pointless if you cant make comptitive/quality thing technologically
if they dont believe that the team will be better by listening to Honda, it's meaningless
In that sense, Honda must be the team that can be on equal terms / equally competitive/qualified
On the inlet issue in 1st session of Barcelona testing (the known problem Nakamura talked about on the 1st day of testing to Japanese media)
vulnerability in variable inlet trumpet - friction between fixed pipe and moveable pipe, distortion in mechanical parts causing breakage
Exchange between barcelona and sakura on 1st day when JB stayed in garage most of the morning session
-- (trumpet got stuck)
engineer at sakura: "Design team reckons it's ok, it wont break down"
-- run by disabling inlet valve
-- need to lock the valve
engineers at Barcelona to Sakura: "lock it by either hydraulic method or binding it by wire?"
engineers at Sakura: "hydraulic lock is fine"
Melbourne race
JB's PU had abnormally high water pressure before the start
Engineer at Sakura: "exceeding 10,000"
stabilized in the race
engineer at Sakura: "water pressure in decline tendency for the last 10 laps or so. At this rate it can make another 100+laps"
