563
Mudflap wrote:
26 Apr 2017, 00:55
I have to take Muniix's side on this.
I don't know nor care what has happened between you two, but he has a very strong point:
Engine design begins with cycle simulations which yield performance figures as well as thermal and mechanical loads.
Manolis doesn't do engine design. He is an inventor who dreams up new concepts. If a few "engine designers" bothered to look beyond the end of their nose and help him out, there are several concepts on his website that are actually superior to anything currently in production and could become viable - Pat OP for example.
J.A.W.
J.A.W.
109
langwadt wrote:
25 Apr 2017, 23:02
Muniix wrote:
24 Apr 2017, 19:59
Pinger wrote:
24 Apr 2017, 19:15
Muniix:
It seems the PWS was retired too early. When there is a rush of new technology, one tends to dominate and others are abandoned never to see any development (that may result in them being superior). In this context, the rush to turbochargers (a relatively known technology - always the trend in the auto industry) with the rise of common rail diesel saw the PWS sidelined. The advance of electronics appear to have given it a second wind...
Similarly - T.Jet ignition. I was looking into similar way back - then common rail diesel arrived and swept all aside. TJet ignition is an old technology which falls under the rubric of 'torch ignition'. No one - despite plenty trying - made much of a success of it. I'm genuinely surprised to see its return, though in the context of lean burn, perhaps inevitable.
TJI was developed here in Australia at Melbourne University by Dr. William Attard who worked on the Bishop team for a few years before he went off to do his PhD. My guess is it was the clever way Bishop used the two offset plugs with squish and the dual cross tumble flow to create the huge central flame kernel and the improvement to combustion that provided that inspired him to work on combustion Ignition to improve engines.
isn't tji really just a modern fuel injected version of Hondas +40yo CVCC ?
No, Harry Ricardo had conceptualized it - long before then..
J.A.W.
J.A.W.
109
& here's a recent 2T concept engine schemed from that Ricardo/R-R Crecy foundation..
http://44teeth.com/sound-god-ripping-underpants/
manolis
manolis
107
Hello all.
Unless I am wrong, there are no patents granted by the US-PTO to Mr. Marc Jackson (munix@gmail.com).
Muniix (Marc Jackson) writes:
Clearly you do not understand the patent protection system, you patent all the implementations. To prevent someone releasing a inferior Implementation and damaging the reputation of your Innovation.
The patent you reference is prior art patents only. Protection from someone producing a bad valve.
I'm not telling anyone to do anything, especially to engage with someone who has no grasp of reality.
You think it's viable to spend millions to sell a few motorcycle heads for crf 450 owners, who can't use them on the road or competition. Hmm that will be $20k+ per head, minimum and still make a loss.”
Let me “apologize” (the following may be proved useful to someone interested in protecting his ideas by patents).
Patents granted to the “Bishop Innovation Limited” (assignee) by the US-PTO:
1 8,033,154 Steering rack manufacture
2 7,950,153 Method of manufacturing a steering rack
3 7,886,567 Steering rack manufacture
4 7,694,656 Cylinder head for rotary valve internal combustion engine
5 7,654,165 Composite steering rack
6 7,621,249 Port sealing in a rotary valve
7 7,584,741 Internal combustion engine with rotary valve
8 7,458,357 Gas sealing element for a rotary valve engine
9 7,401,587 Gas and oil sealing in a rotary valve
10 7,168,282 Method and apparatus for manufacture of a forged rack
11 7,000,444 Forging method and apparatus
12 6,994,067 Valve timing mechanism for a rotary valve internal combustion engine
13 6,789,042 Position encoder using statistically biased pseudorandom sequence
14 6,763,788 Variable timing mechanism for a rotary valve
15 6,759,648 Sensor for sensing absolute angular position of a rotatable body
16 6,624,900 Optical sensor
17 6,617,994 Capacitive flash analog to digital converter
18 6,528,783 Position sensor and circuit for optical encoder
19 6,501,068 Method for manufacture of optical torque transducers
20 6,450,044 Torque transducer
Seven of the above patents of the “Bishop Innovation Limited” relate directly with rotary valve engines; and only the two of them (7,584,741 and 7,401,587) are still “in force”( the rest five have lapsed due to not payment of the required maintenance fees).
Regarding the “strength” of the above two, still in force” US patents of Bishop:
The only independent claim of the US7,584,741 is:
1. An axial flow rotary valve internal combustion engine comprising: at least one rotary valve rotatable about an axis within a bore of a cylinder head, said valve communicating with a respective cylinder in which a piston reciprocates, and an ignition means associated with said cylinder, said rotary valve having an outside diameter less than 0.85 times a diameter of said cylinder, an inlet port extending from an inlet axial opening at one end of said valve and terminating as an inlet peripheral opening in a periphery of said valve, an exhaust port extending from an exhaust axial opening at the opposite end of said valve and terminating as an exhaust peripheral opening in the periphery of said valve, said peripheral openings periodically communicating with said cylinder through a window in said bore as said valve rotates, said window having a first window end proximate to said inlet axial opening and a second window end remote from said inlet axial opening, a combustion chamber formed in a space between a crown of said piston at top dead center and said cylinder head and said valve, said head having a combustion surface surrounding said window and extending to a wall of said cylinder, wherein said window and said valve are substantially centrally disposed about a first plane within which the axis of said cylinder lies, said ignition means comprising first and second spark plugs, each of said spark plugs having a nose located at one end thereof exposed to said combustion chamber through said combustion surface, said noses being disposed on opposite sides of said window within axial extremities of said window, and an intersection point of an axis of each of said spark plugs with said combustion surface is radially inside said wall of said cylinder by a distance of at least 0.1 times the diameter of said cylinder, and said combustion chamber has first and second squish zones, at least a portion of each of said first and second squish zones being between the wall of said cylinder and the nose of each of said first and second spark plugs respectively.
The only independent claim of the 7,401,587:
1. A rotary valve assembly for an internal combustion engine comprising an axial flow rotary valve having a cylindrical portion, and an inlet port and an exhaust port terminating as openings in said cylindrical portion, a cylinder head having a bore in which said valve rotates about an axis with a predetermined small clearance between said cylindrical portion and said bore, a window in said bore communicating with a combustion chamber, said window being substantially rectangular in shape and said openings periodically communicating with said window as said valve rotates, bearing means journaling said valve in said bore, an array of floating seals surrounding said window, and a bias means preloading said array of floating seals against said cylindrical portion, said array of floating seals comprising at least two spaced apart elongate axial seals adjacent opposite sides of said window and at least two spaced apart arcuate circumferential seals adjacent opposite ends of said window, each said axial seal being housed in a respective axially extending axial slot formed in said bore, and each said circumferential seal being housed in a respective circumferentially extending circumferential slot formed in said bore, characterised in that said circumferential seals are axially disposed between the ends of said axial seals.
Having just one independent claim, it means that every other claim of the patent “depends” on the independent claim, i.e. every dependent claim has all the limitations introduced by the independent claim plus its own limitations.
Question:
Are the above two “still in force” patents of Bishop Innovation Limited “strong” enough?
Suppose you want to “bypass” the US7,584,741 patent (i.e. to make, use or sell it in the territory of the USA without paying “royalties” to “Bishop Innovation Limited”).
The simplest way to “bypass” the patent is to select a “rotary valve having an outside diameter bigger than 0.85 times a diameter of said cylinder”.
Or, say, to use one only spark plug (or, better, a “laser spark plug” which ignites the mixture at the center of the rectangle window, wherein it is not possible to be disposed a conventional spark plug).
Suppose you want to “bypass” the other, “still in force”, US7,401,587 patent of Bishop (i.e. to make, use or sell it in the territory of the USA without paying “royalties” to “Bishop Innovation Limited”).
A simple way is to select a “slightly oblique” arrangement of the sealing means and grooves (the axial seals turn to slightly “helical” seals, which, by the way, can better fit with the oblique separator inside the Cross rotary valve).
Alternatively, you can have the circumpherential seals extending outside the ends of the axial seals, with the axial seals disposed between the ends of the circumpherential seals.
And so on.
Bishop Innovation Limited was a multi million dollar company.
The guys worked in the Bishop rotary valve project were smart guys.
Then why they wrote such “vulnerable” patents?
A reasonable answer is that they had to present “results” and “protection” to their investors.
I bet that if they were spending their own money for the patenting, they would never file such patent applications.
The rotary valve patents of the Bishop Innovation Limited are not “basic patens”, i.e. they are not patents presenting something fundamentally different than the prior art, but “patents dealing with the improvement of details of the prior art”.
Here is the first claim of the PatRoVa rotary valve, for comparison (the GB2525704 patent has already be granted by the UK-IPO and is in force, the US patent is approved and is to be granted with the payment of the US480$ Issue Fee):
1. A disk rotary valve assembly for reciprocating piston positive displacement machines, the disk rotary valve assembly comprising at least: a cylinder (30); a cylinder head (5); a piston (40) reciprocally fitted in the cylinder (30); a chamber (50) defined inside the cylinder (30), the chamber (50) is sealed at one side by the piston (40), the chamber (50) is sealed at another side by the cylinder head (5); the cylinder head (5) comprising passageways (20, 17) for the introduction of gas in the chamber (50) and for the evacuation of the chamber (50) from the gas; the cylinder head (5) comprising a pair of oppositely arranged chamber ports (12), each chamber port comprising a lip (13) at its end; a disk rotary valve (1), the disk rotary valve (1) being rotatably mounted in the cylinder head (5), the disk rotary valve (1) rotating about a rotation axis (60) in synchronization to the piston reciprocation; the disk rotary valve (1) comprising a pair of oppositely arranged fronts (8), each lip (13) being in gas tight sealing cooperation with a respective front (8) of the disk rotary valve (1), the orthogonal projections of the oppositely arranged fronts (8) on the rotation axis (60) of the disk rotary valve (1) being at a substantial distance from each other; the disk rotary valve (1) comprising valve ports (10, 9), during a part of a rotation of the disk rotary valve (1) the chamber (50) communicates, through the valve port (10, 9) with passageways (20, 17), during another part of a rotation of the disk rotary valve (1) the fronts (8) seal the chamber ports (12), isolating the chamber (50) from the passageways (20, 17), the chamber ports (12) being arranged so that the total force applied on the disk rotary valve (1) due to a high pressure inside the chamber (50) to be several times smaller than the force applied separately on each front (8) due to the same high pressure inside the chamber (50).
And here is the 19th claim (which is also an independent claim) of the same patent for the PatRoVa, which may seem more simple / comprehensible to the forum member / reader:
“19. A disk rotary valve assembly for reciprocating piston positive displacement machines, comprising at least: a cylinder; a cylinder head; a piston reciprocally fitted in the cylinder; a chamber defined inside the cylinder, the chamber is sealed at one side by the piston, the chamber is sealed at another side by the cylinder head; the cylinder head comprising inlet passageways, exhaust passageways and a cavity, the cavity being a part of the chamber; the cylinder head comprising a pair of oppositely arranged chamber ports at two opposite sides of the cavity, each chamber port comprising a chamber port lip at its end; a disk rotary valve rotatably mounted in the cylinder head and rotating in synchronization with the piston reciprocation, the disk rotary valve comprising a pair of oppositely arranged fronts, the cavity being disposed between the pair of oppositely arranged fronts with each chamber port lip being in gas tight sealing cooperation with a respective front of the disk rotary valve, the disk rotary valve comprising valve ports, for a part of a rotation of the disk rotary valve the chamber communicates, through the valve ports, with some of the inlet and exhaust passageways of the cylinder head, for another part of a rotation of the disk rotary valve the chamber is sealed from the cylinder head passageways, the arrangement is such that the total force applied on the disk rotary valve due to a high pressure inside the chamber being many times smaller than the force applied separately on each front due to the same high pressure inside the chamber.”
Compare the above claims with the claims of the “still in force” two US patents of Bishop.
The PatRoVa patent is a “basic patent” because it introduces a completely different kind of rotary valves not existing before.
Just like most of the rest patents of pattakon.
Granted patents to pattakon by the US Patent and Trademark Office (US-PTO):
9,303,637 Connecting rod valve
9,273,605 Variable compression ratio engine
9,175,731 Constant velocity joint
9,022,005 Rotary engine
8,910,597 Reciprocating piston engine
8,776,749 Desmodromic hydraulic valve train
8,747,236 Constant velocity joint
8,662,031 Uniflow portless two-stroke engine
8,267,055 Variable compression ratio engine
8,220,422 Rack gear variable compression ratio engines
8,201,531 Desmodromic variable valve actuation
8,166,948 Throttle-less engine with improved variable valve system
8,166,929 Variable compression ratio engine
7,909,012 Pulling rod engine
7,765,965 Fully variable valve actuation
6,892,684 Variable valve gear
6,062,187 Pulling piston engine
Patent Applications of pattakon for which the granting of the patent has been already approved (Notice of Allowance):
20150345372 ASYMMETRIC TRANSFER AND INTAKE IN TWO-STROKES
20150233270 DISK ROTARY VALVE HAVING OPPOSED ACTING FRONTS
Thoughts?
Thanks
Manolis Pattakos
By the way, here is the reply e-mail (I think it is the 26th email received by Mr. Marc Jackson) of my “bet e-mail”:
-----Original Message-----
Sent: Monday, January 16, 2017 7:50 AM
To: man@pattakon.com
Subject: Re: Hi, thought this paper on variable inertia effects from University of WA be of interest
Hi Manolis,
What I did learn on the weekend was about another project, An engineering consultancy business here is doing work for an Indian company that manufactures transmissions and is expanding into supplying a full drive train for personal transport vehicles.. The company currently has no engine assembly line, they are starting with a clean sheet and so can implement any engine architecture without the usual considerations that limit innovation a existing production line has. This makes them an ideal proposition to look at innovative low cost, efficient engine designs. I mentioned your site and inventions, they could well be interested in some form of licensing and collaboration if they find something that suits the purpose.
We could do the CFD work and I'll get a nice bonus for bringing in the work. Any of your engine designs with a a modern smart engine management system could well be suitable, would require significant engineering work to make them fit for purpose, with cooling, intake, exhaust, combustion optimisation and emissions taken into consideration. Imagine a very light power train, mid engined horizontally opposed two cylinder like a Porsche 911 using one of their existing automated manual transmissions all controlled by a simple smart power-train management system!
So I showed them some conversations, how relevant information was ignored, dismissal of technical arguments that didn't fit opinions, the dual spark plug really had them worried, after the details of how dual plugs improved the Ducati Testastretta DS 11 degree engines from 150-160hp, and the 11% fuel saving, the following statement that all dual plug systems have been failures and abandoned. Had them really concerned it was irrational, and after it was explained how squish was used to provide a superior flame kernel in dual offset spark plugs, several times etc and how this was a repeated theme over and over about all sorts of issues, flow coefficients, intake pressure waves and gradients, understanding of cooling considerations and combustion, chemical species produced, fluid flow arguments, they then considered they could not work with such a person. These issues destroy projects, there would have to be something really impressive to persuade them otherwise.
On 13 January 2017 at 17:18, <man@pattakon.com> wrote:
Hello Marc.
Automakers do their best to maximize their profits.
They should not be accused for this.
Maybe they should look more at the long term profit, however it is their own decision.
Fortunately, there are other ways for something good to get in the market.
Thanks for your time to think about the PatRoVa, as well as for your estimation / calculations about the "PatRoVa vs Bishop" flow, no matter how much I disagree.
Are you confident about your calculations?
A bet, starting with US1,000$ that increase geometrically depending on the mistake / error of your calculations (I explain in the following how) can make things interesting.
According your e-mails, there is a running (and in perfect condition) Honda CRF450 with the Bishop rotary valve on it.
I suppose there is a dyno test which can be reconfirmed any time it will be asked by me (we can arrange how).
I suppose, also, the dyno test is not confidential.
So, here is how the "bet" will "work":
You will start with the dyno test of the specific Bishop CRF450, you will calculate (it will be easy based on the 200% better flow of the Bishop) the fall of the peak power in case the cylinder head is replaced by a PatRoVa, and you will provide me the data.
Then I will modify a Honda CRF450 to PatRoVa (the form of the window(s) / ports, the diameter of the valve and every other detail of the design is my own business).
And I will dyno test it (with the dyno test being reconfirmable if you ask so (we can arrange the details)).
If you are correct, you will take my US1,000$ and the satisfaction you know what you say.
If not, for every +10% difference in peak power (the 10% refers to the peak power of "your" Bishop CRF450) from your calculations, the amount to be paid by you doubles.
For instance, if the Bishop CRF450 makes on the dyno 100PS, and according your calculations no more than 60PS peak power can be made by the PatRoVa CRF450, then, if the dyno writes 110PS for the PatRoVa CRF450 (i.e. 5*10% above your calculation), you will pay to the UNICEF (not to me) 2^5=32 times the initial amount of the bet (i.e. US32,000$) and you will sent me the receipt to publish it in the PatRoVa web page.
The US1,000$ I will pay in case you prove correct, may seem not much, however don't forget the cost to make a decent quality PatRoVa prototype,
If your friends at Bishop like so, they can bet, too.
Have a nice day.
Manolis Pattakos
J.A.W.
J.A.W.
109
Muniix wrote:
25 Apr 2017, 17:01
...I'm not telling anyone to do anything, especially to engage with someone who has no grasp of reality.
Marc, the CR450F is an MX competition machine, sold in fairly large numbers worldwide..
..& AFAIR, the MX racing rules do not actually ban 4T rotary valves.. ( as for Moto 3, I dunno)..
Anyhow..
If the attributes you claim for the Bishop system do indeed give a marked performance increase..
..then there is very likely a market for them, & thus at least - also worth doing a feasibility study..
.. perhaps paid for by those prior investors - who would like to realize some return on funds spent?
63l8qrrfy6
63l8qrrfy6
368
gruntguru wrote:
26 Apr 2017, 04:35
Mudflap wrote:
26 Apr 2017, 00:55
I am not going to hide that I am a bit biased here - I have only ever designed engines that are very conventional by comparison. For me changing a crush relief height by half a mm or increasing a valve seat angle by a few degrees are fairly ambitious endeavors.
But even so, I believe that for you to claim that they are superior to anything in production is blatantly unfounded.
As I have mentioned before, my engine performance knowledge is very limited, but I don't have to open Heywood to tell that the combustion chamber on that Pat OP is far from ideal. Or that if you use 'four stroke lubrication' you will need to lubricate the top piston which means you can only install the engine horizontally otherwise oil will pool in the bores. And it still has all the disadvantages of any 2 stroke running rings past the port windows but with added inertia and complexity.
How can we even judge these engines - are they meant to achieve anything in particular ? If their sole purpose is to put a name against a patent then they sure do look like they are doing an amazing job. But if they are intended to develop outstanding performance or maybe better emissions or lower costs - we have nothing to go by at all, no data to assess these criteria other than some CAD models. It is a lot like arguing over what the weather is like in heaven.
I want to make it very clear that my intention is not to offend anyone - I really do appreciate hard work and passion, but in this case I fail to see the point.
563
Mudflap wrote:
27 Apr 2017, 03:34
. . . I don't have to open Heywood to tell that the combustion chamber on that Pat OP is far from ideal. Or that if you use 'four stroke lubrication' you will need to lubricate the top piston which means you can only install the engine horizontally otherwise oil will pool in the bores. And it still has all the disadvantages of any 2 stroke running rings past the port windows but with added inertia and complexity.
The Pat Op is subject to the same constraints as any opposed piston design - Jumo, Deltic, Commer Knocker, OPOC etc. It just happens to do it better and with less inertia than any of these and so makes the significant advantages of the opposed-piston, uniflow, 2 stroke diesel somewhat more realisable.
manolis
manolis
107
Hello Mudflap
You write:
“As I have mentioned before, my engine performance knowledge is very limited, but I don't have to open Heywood to tell that the combustion chamber on that Pat OP is far from ideal. Or that if you use 'four stroke lubrication' you will need to lubricate the top piston which means you can only install the engine horizontally otherwise oil will pool in the bores. And it still has all the disadvantages of any 2 stroke running rings past the port windows but with added inertia and complexity.
How can we even judge these engines - are they meant to achieve anything in particular ?”
What is the “ideal combustion chamber”?
Achates Power (100 million dollars invested so far, WalMart is one of their famous investors / supporters ) claims their opposed piston engines have the ideal combustion chamber (it is so efficient, they say, that it achieves a substantially reduced BSFC as compared to the best similar size / power 4-stroke Diesels).
Regarding the lubrication:
The PatOP engine and the OPRE engine have “four stroke like” lubrication which is explained at http://www.pattakon.com/pattakonPatOP.htm and http://www.pattakon.com/pattakonOPRE.htm , from where the following Quote is:
“The transfer of the wrist pin - i.e. of the thrust loads - away from the hot combustion chamber and away from the ports, solves another problem of the opposed piston engines: it allows "four stroke" like lubrication and oil consumption.
OPRE's piston skirt can avoid the touch with the hot cylinder wall because the thrust loads are taken at the other side of the piston, onto the cool, rid of slots and well lubricated cylinder wall of the scavenging pump.
In comparison, the piston skirt of the conventional opposed piston engine thrusts heavily onto the hot, especially at exhaust side, cylinder wall, around the port area where the openings restrict the contact surface, requiring plenty of lubricant and inevitably resulting in lubricant consumption., at the cold side “
End of QUOTE
For comparison, here is the initial version of the Achates Power engine, for which, according their lab tests, the lube specific consumption equals to that of the best 4-stroke engines:
This “like four stroke” lubrication is possible only because the pistons skirts are rid of thrust loads (two synchronized crankshafts at the sides of the cylinder, multiple connecting rods per piston etc).
In their last engines (for DARPA / US Army etc) Achates Power seems abandoning their original two side crankshaft design and adopting the conventional arrangement of the Junkers Opposed Piston (two crankshafts on the cylinders plane):
If you look at the middle cylinder of the following drawing, the two opposed pistons have their skirts (whereon the thrust loads are taken) above the ports of the cylinder liner:
The requirements are incompatible:
On one hand it is necessary a thick film of lubricant on the cylinder liner, around the intake and exhaust ports, to provide (at least partly) hydrodynamic lubrication in order to keep the frictional losses acceptably low,
on the other hand, plenty of lubricant on the cylinder liner, around the ports, means loss of lubricant either towards the exhaust, or towards the combustion chamber.
It is not only the “four stroke like” lubrication.
The crosshead pulling-rod arrangement of the pattakon OPRE, PatOP engines (which results by a small change in the basic architecture of the conventional engines) offers several other advantages.
After reading the above mentioned PatOP and OPRE web pages, let me know what you don’t get to try to explain it.
By the way,
for “true 4-stroke lubrication” in the through scavenging / uniflow 2-strokes, look at the http://www.pattakon.com/pattakonPatMar.htm and http://www.pattakon.com/pattakonPatPortLess.htm web pages (pattakon PatMar and PatPortLess engines).
Thanks
Manolis Pattakos
J.A.W.
J.A.W.
109
I 'd also point out that the US military forces are exempt from civilian emissions reg's, hence the
nearly 80 year old Detroit Diesel 2T engines remain in production, on the basis of their military utility..
manolis
manolis
107
Hello J.A.W.
Talking for 2-strokes, here are the specifications of the Wartsila X92 (3468mm stroke, 920mm bore), a modern giant 2-stroke marine engine of top BTE (Brake Thermal Efficiency).
Here is a connecting rod of it:
spot on the “center-to-center” length of the con-rod: 3468mm. i.e. equal to the piston stroke.
I.e. the connecting rod to stroke ratio is 1.
Here is the cross head:
Despite the extremely short connecting rod (the leaning angle of the connecting rod relative to the cylinder axis varies from -30 to 30 degrees) the hydrodynamic lubrication of the cross head eliminates the relative frictional loss.
And here is the “design concept” of the X92:
The design of the following PatOP is based on the cross head architecture, too.
Lubricant under pressure is provided to the slippers of the cross head in a way similar to the way lubricant under pressure is provided to the crankshaft bearings (main journals and crankpins).
Plenty of oil under pressure in the cross head, and only a thin oil film on the cylinder liner whereon the piston rings slide.
As compared to the Junkers engines of the Achates Power, the specific lube consumption will be several times lower.
Thanks
Manolis Pattakos
Pinger
Pinger
Muniix: Thanks for the replies re steel pistons and TJI. Much appreciated.
langwadt wrote:
25 Apr 2017, 23:02
The main difference between TJI and all the other torch ignition appears to be the (pre) chamber volume. Very small in TJI, much larger in torch systems - which led IIRC to large throttling and heat losses.
The Crecy chamber: Ricardo on his experimental engine derived from Crecy stated (IIRC) that the 'bulb' was to trap a richer mixture to enable stable running at low load (deleted a valve from the injector that was there to enable a sharp fuel cut off). More just to get the fire lit than promote further ignition of a weak mixture. A ''degree of stratification'' was his description I think.
63l8qrrfy6
63l8qrrfy6
368
gruntguru wrote:
27 Apr 2017, 05:34
Mudflap wrote:
27 Apr 2017, 03:34
All but one of those engines are over half a century old while OPOC was either a scam or a miserable failure.
I've not seen inertias tabulated anywhere so I can't give you that either. Repeating that his engine is somehow better will not make it true.
The ideal combustion chamber is whatever offers the largest flame front area, fastest burn rate and minimal flame-wall contact. Heywood specifically states that a disc shaped chamber (rectangular cross section) where the flame initiates from the side is the worst in terms of combustion speed.
Sure, Achates have blown 100 million on testing and simulation - it only makes sense that they have managed to develop a very efficient engine. But what is to say that your engine will have similar performance - just the fact that it too uses opposed pistons ?
Piston skirts as well as compression rings in conventional pistons also operate in a hydrodynamic regime except during reversals (but then the same happens for crossheads too). And guess what - if you have a look at a Striebek curve you'll find that the coefficient of friction is minimal during mixed lubrication and steadily increases as you go further into the hydrodynamic regime. Your argument regarding the elimination of frictional losses is invalid. You are just moving the forces from the skirt to the crosshead.
You will also find that the total friction due to piston rings (worst culprit being the oil ring) is higher than the skirt friction in conventional skirt guided piston 4 strokes. Which leads me to oil consumption.
You will still have to lubricate both ring packs, but there are now twice as many (not counting the scavenging piston) I struggle to see how you can magically reduce consumption when you are effectively doubling the potential for oil loss. Sure, you are reducing the piston secondary motion and that should help, but blow by and oil consumption are mainly driven by inter-ring fluid dynamics and the dreadful effects of rings running past port windows.
563
Mudflap wrote:
27 Apr 2017, 23:48
Yet Achates persist with a Jumo copy? If you took the time to read Manolis stuff you would realise that OPOC's shortcomings are fairly obvious and are all addressed by the Pat OP.
563
Mudflap wrote:
27 Apr 2017, 23:48
You must be reading the section on spark ignition. These are Diesel engines. Regardless, if you look at the Pat OP above you will see the combustion chamber (at TDC) is anything but a pancake.
563
Mudflap wrote:
27 Apr 2017, 23:48
Which is a key benefit of the cross-head design.
1. Elimination of tilting of the piston improves efficiency of all the rings allowing reduced ring tension and reduced lubrication.
2. Eliminating the skirt as a cross-head bearing further reduces the quantity of oil required on the bore.
I am sure this is not a deliberate attempt to mislead and you simply overlooked the fact that the extra piston contributes its own displacement, so oil consumption as a function of engine displacement remains the same were you to substitute the opposing piston with a cylinder head.
