Hello, first part of a report on BMW F1 cars with BMW F1 turbo engines ( the most powerful in the history of Formula 1) and Brabham BT52. That's here, enjoy :
http://www.gurneyflap.com/focusbmw.html
riff_raff wrote:benjabulle,
The Brabham BT52 with the "laydown" BMW engine was a great engineering concept. However, it's my understanding that it did not perform as promised because the engine had an oil scavenge problem and thus suffered severe crankshaft windage losses. Oil would accumulate within the low ground clearance sump and could not be removed, due to the direction of the crank rotation and the position of the oil scavenge pump pick-ups. A crank/rod assembly trying to pass through a slug of oil gets slowed down significantly. Thus the engine had very poor throttle response.
When the engine was converted to a more upright installation, it performed much better.
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 2 guests
