With the fuel limits next year, a large part of the competitive advantage will come from fuel efficiency, and measures such as cutting drag so less fuel goes into countering drag. L/D ratios will probably come to the fore over sheer downforce figures as that could be for nought if you need to fuel save every lap of the race.
Assuming two cars A and B where both have identical amounts of drag at any given speed, but Car A has more downforce (ie a better L/D ratio) then how does that affect fuel consumption?
Car A, in effect, would be on throttle for longer distances (shorter braking & traction phases) but then it wouldn't have to accelerate as hard anyways as it's carrying more speed.
On the other hand, the one with less downforce will have to accelerate harder on exit as it carries less speed.
I can see that if you're at a track like Hungary then Car A will dominate Car B, but will they use more fuel thanks to having to maintain a higher average rpm through the lap? Of course if the difference is more extreme they could in fact end up going a gear higher but on similar (or slightly lower) revs than Car B
Any and all guidance appreciated.
