flynfrog wrote:L/D drag ratios have always been important over sheer DF. Every time they save some drag that is more DF they can crank on the car. The ratio might shift to a different target but the goal has always been to maximize L/D ratio for a given target lap time.
Exactly. In 2014 the fuel cap at 10.500 rpm has the same function that the rev limit at 18.000 had in this season. It is a power limiting formula. This year everybody revs up to 18.000 and you can expect everybody to inject 27.8 g/s next year. Fuel use differences will only apply off throttle and to overrun programs.
This year you have different top engine power from different torque curves. Next year you will have different top power from different ICU efficiencies and different energy reclaim management. But that has no impact on aero strategies.
Engineers will do absolutely the same that they have done all the time when they have faced a new aero config with reduced downforce and a different power characteristic. That is what we will have next year. They will design the floor and the air flow over the chassis in such a way that they have the highest aerodynamic efficiency. Only then will they optimize the wings by size and angle of attack for each of the tracks. They will trade cornering speed for for straight line speed until they have found the maximum performance compromize for each track and their particular engine and chassis characteristic. Actually it is a bit more complicated because tyres may still not allow the full performance optimization but I hope it will not be the case.
In the end nothing of the whole process will have much to do with fuel consumption. The only factor that will marginally impact on fuel consumption is electric energy management. If teams decide to use excessive electric power generation in the over run they could jeopardize the ability to use the full fuel rate at 10.500 rpm.
Running an optimum lap program that does not reflect the regulations and technology that we will have next year does not give you reliable information what is going to happen IMO.
