DFV block height
Post Sun Dec 23, 2007 3:53 pm
Hi everyone, would anyone be able to tell me the block height for the first series cosworth DFV engine and maybe the rod length as well, thanks
kal
Post Sun Dec 23, 2007 5:19 pm
Welcome to the forum kal. Sounds like your doing a rebuild. I'd recommend factory sources for information.
http://www.cosworth.com/
A few years back my dentist had a 1969 DFV block covered with a glass sheet as a living room coffee table, probably been replaced now he is a Ferrari enthusiast. It's a sensitive subject, argue with him and he holds back on the Novocaine, very painful [-X
Carlos
Post Sun Dec 23, 2007 5:48 pm
Hi Carlos, thanks for the info.Yes i'm in the process of doing a build.I wish it was a DFV i was building but actually it's a BDA.
I'm using the cosworth DFV pistons part number DA1964 to build a BDE spec engine.
Only problem is they protrude out from the block face by about 2mm.
Accralite list these pistons with 37.3mm compression height which would put them flush with the block face, but the cosworth ones seem to be 39.3m compression height.
I assumed they would be the same as the accralite equivalent so didn't ask when i ordered them #-o .
Now i have pistons 2mm too tall, i don't fancy machining the tops as i'd like to keep the strength in the crown...
Anyway i thought i'd ask here as i'm trying to ascertain which DFV pistons i actually have and why the accralite equivalent are 2mm lower in comp. height :?
I'll get in touch with cosworth but that will be after the holidays now
kal
Post Sun Dec 23, 2007 6:54 pm
kal it's very possible the deck height was machined. Projects should start with research, in the case of an engine rebuild, accurate measurements, which means specification sheets and a substantial investment in precision tools. Here are some helpful calculators.
Deck Height Calculators
http://www.kb-silvolite.com/calc.php?action=deck
Collection of Engine Rebuild Calculators
A Good Source of Measuring Tools & Acessories
Which can often be bought at a better price point on e-Bay
Carlos
Post Sun Dec 23, 2007 10:06 pm
kal wrote:I'll get in touch with cosworth but that will be after the holidays now
And till than enjoy in this :wink: viewtopic.php?f=4&t=3497
manchild
Post Sun Dec 23, 2007 11:04 pm
I can see I repeated a link :roll:
Here is a source of measurement instruments:
http://www.machinetools.com/MT/machines ... oupid=8070
Carlos
Post Mon Dec 24, 2007 8:08 am
Ford BDE 1790cc Engine Specifications
Reprint of original Cosworth material. 45 drawings and technical specifications
http://www.lotus-books.com/html/body_engines.html
Carlos
Return to Engine, transmission and controls
Who is online
Users browsing this forum: AddThis [Crawler] and 4 guests
