Fri Aug 14, 2009 12:40 pm
None are directly proportional to speed. This is why I was saying that you discover interesting occurances when simulating systems and looking at dyno results or friction rig results.
Power loss would be force * speed yes, but the force in question is constantly changing. So if the speed goes up, you must also bear in mind what happens to the force. The force involved is the force excerted in the con-rod, be it tension of compression, this then acts on the cylinder wall at an angle dependant on crank angle and engine geometry.
Build up a simple model to show piston acceleration through the opperating cycle. You will then observe that the areas of positive and negative acceleration are not the same.
I won't go in to it any further as it would appear you don't want to.
I am not going to disclose figures about the engines unfortunately but what I can tell you is, 320kW is not close.
