Tire speed when braking.
Caito
Caito
Hi guys!
I've read a couple of times ( can't remember exactly where ) that when "treshold braking" the tires spin ~15% slower than the car's actual speed.
If so, what's the logical explanation? What I can imagine is that as the tire is rolling slower the contact patch is deforming, rubber is deformed absorbing energy braking the car. Coefficient of Friction increases when rubber is deformed?
What would happen if tires spun 20% slower? Too much deformation? How does an even slower tire reduces braking force.
Does ABS take this into account? How can an ABS know when it's on peak braking force.
Last, but not least. Does the same apply to accelerating?
Thank you very much!
Caito.-
Come back 747, we miss you!!
jon-mullen
Re: Tire speed when braking.
I'd think that ~15% slower figure is an average because for small amounts of time the wheels are locked. Could be mistaken.
Caito wrote:Does ABS take this into account? How can an ABS know when it's on peak braking force.
On my road car the ABS has wheel speed sensors and a computer that compares wheel speed to the car's speed and modulates the brakes accordingly.
Loud idiot in red since 2010
United States Grand Prix Club, because there's more to racing than NASCAR
of course you need tyre slip to generate grip.So this is the something of a difference distance travelled and corresponding tyre revolutions,nothing spectacular there.
the 15% slip seems a lot to me i think the the optimum value could be nearer 8% slip in braking ?
Bigger slip values will not yield better braking only more smoke and abrasion,as is obvious in forward acceleration: if you try too hard the forward traction goes up in smoke...easy as that .If you do not operate at the optimum slip percentage you sacrifice acceleration.
Caito
Caito
Thank you very much guys!
xpensive
xpensive
214
I suspect that understanding the difference between static and kinetic friction is a good basis for this discussion.
Wikipedia can sometimes be helpful with bringing scientific enlightment on things like this;
http://en.wikipedia.org/wiki/Friction
alexbarwell
alexbarwell
My understanding of ABS systems is that the wheels carry a tacho ring and sensor. If the tacho system the wheel's turn rate has dropped very sharply (like a wheel locking up) then it will modulate the brakeline pressure and briefly release the brakes to allow the wheel to unlock and regain grip before restoring braking effort. As this happens quickly (but varies between different cars)the sensation can manifest itself as a knocking, thumping noise. Modern ABS system can be integrated with traction control as the wheel speed when spinning with lost traction can be picked up by the same tacho wheels, and with electronic braking distribution in there as well, can apply proportional braking to a side or corner to allegedly optimise braking.
I am an engineer, not a conceptualist :)
Jersey Tom
Jersey Tom
xpensive wrote:I suspect that understanding the difference between static and kinetic friction is a good basis for this discussion.
...it would be, but rubber tribology doesn't follow Coulomb friction.
xpensive
xpensive
214
Feel free to enlighten us then?
mep
29
None of the posts here and in other threats about tyres really satisfy me. It seems like most of the people have a false understanding of what happens with a tyre. Especially the term “slip” leads to most of the misunderstandings. Obviously most of you think of a tyre as of a totally solid piece. In fact it is made of rubber so it can deform quite a lot. Rubber changes the things quite a lot that’s why a train (steel) has other characteristics than a car (rubber).
First thing we will notice is that rubber can generate much more friction than metal. The second thing is that the friction coefficient isn’t a fix number anymore. It is a variable figure. So applying the equations from Coulomb may lead to wrong results in some cases. But that’s not the topic now.
No.
You are quite close.
Imagine a piece of rubber like an eraser resting on a surface. When you try to push it in one direction you put a force on it. The rubber will get deformed until the forces in the rubber are in equilibrium with the applied force (F1). When you put more force on the rubber it will deform even more similar to a spring. The coefficient of frictions stays constant and it is still static friction.
When you try to push even more you will reach a point where the friction between the rubber and the surface is not big enough to hold the rubber on its place. The rubber will start to slide (V). Then static friction changes to dynamic friction which is much smaller. So the force (F2) who is deforming the rubber gets also smaller what will cause the rubber to bounce back a little bit.
There is one special case possible we know as “stick-slip”. After the rubber element has bounces back it will stop its movement along the surface for one instance. At this instance it will have static friction again and will start to deform again. The rubber element will always switch between static and dynamic friction. This causes oscillations in the rubber element and the squeezing noise. It’s something like the transition between static friction and dynamic one and warning the driver that he is close to the limit.
On a tyre these things get more complicated. I read 2 books about that stuff now and got it like this.
Basically we have lots of those rubber elements and arrange them now on a circle. What we want is static friction because this will give us the highest friction coefficient and that’s what we have most of the time. A tyre is somehow similar like the chain of a tank. While the elements touch the ground they don’t move or slide along it (static friction). Just that the rubber on a tyre is flexible. While entering the contact patch the rubber elements get deformed and moved slightly. Therefore the contact patch gets slightly bigger than the one of a metallic wheel. During the contact patch they stay on the ground. When they are leaving the contact patch they bounce (sliding on the surface) back to their original position.
The trick is that they are arranged on a circular pattern and every element moves slightly. When you add up this movement you will get an effect like the top layer of the tyre would spin a bit faster or slower (depends whether you are braking or accelerating) than the rest does. In fact the elements bounce back after they have left the contact patch, so the tyre sticks together.
Another thing to take into account is that the tyre radius is slightly smaller on the contact patch. Changes of the radius also changes the demanded revolutions of the tyre of course. I guess these has already being taken into account be definition of the slip ratio.
There are several different definition of the slip ration. SAE defines it like this:
SR=(Ω-Ω_0)/Ω_0
Ω: angular velocity of the driven or braked wheel
Ω0: angular velocity of the free rolling wheel (no force applied)
So when you get such a figure like slip ration = 0,15 it doesn’t mean that the wheel is locked 15% of the time or whatever you might think…..
It also doesn’t mean that the tyre is sliding over the surface. There are still areas where the tyre sticks to the surface. SAE defines spinning with a SR of +1 and locked with SR of -1.
The basic principle is the same but the force acts in a different direction.
During acceleration the force acts in the other direction as the movement of the elements and therefore slows them down while they enter the contact patch. So the tyre has to spin faster.
During braking the force acts in the same way as the elements move. So the tyre has to spin slower.
I really hope this helps because it took me several hours to find out and writte here.
roost89
roost89
Thank MEP, nice article. I certainly understand more about the tyre during breaking and acceleration! =D>
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
xpensive
xpensive
214
roost89 wrote:Thank MEP, nice article. I certainly understand more about the tyre during breaking and acceleration! =D>
Absolutely, brilliant display actually, this one will go to the archive. =D>
jon-mullen
Oooooh. Nice write up, danke.
Caito
Caito
Wohoo! Thank you very much indeed. I'll have to read it a couple more times though
Caito.-
EDIT:
Mep, would you mind giving the titiles and/or authors of books that contain such information?
Thank you!
mep
29
I have searched for a few youtube videos and found those.
They might help to clarify it. Unfortunately the quality is bad.
[youtube]http://www.youtube.com/watch?v=3Ug6w4ZjwVo[/youtube]
[youtube]http://www.youtube.com/watch?v=KLtNvSL- ... re=related[/youtube]
[youtube]http://www.youtube.com/watch?v=I423nw30 ... re=related[/youtube]
The next one is probably the best one:
[youtube]http://www.youtube.com/watch?v=yb8SU4TR ... re=related[/youtube]
The last one is a burnout the wheels turn way to fast so the rubber slips over the surface all the time. You can also notice that the car is hardly moving. Thats normaly not what you want.
[youtube]http://www.youtube.com/watch?v=KOIkkEar ... re=related[/youtube]
Race car Vehicle dynamics by Millliken
Rennwagentechnik by Michael Trzesniowski
(it is a German one I don’t know how much it will help you)
They explain quite a lot but they both lack a good explanation why this slip occurs. Or maybe you have to read between the lines so that’s how I understand them.
