bhallg2k wrote:
Oh, I don't know about that last bit.
Race car's carbon fiber frame also acts as a battery
(And to think, "they" laughed at me when I proposed a battery-floor as a possible design for the mythical Ferrari "Byrne floor" rumored during preseason testing.)
Isn't that just making batteries structural? Like a gearbox?
As far as I know the Dyson-Lola tries to use the batteries as part of the front subframe. This improves packaging (and in LMP weight distribution) and weight (a little bit).
richard_leeds wrote:The real problem is the form factor, being able to squeeze the packaging into the smallest space. A smaller less efficient system would be preferable to a large efficient system. This is a function of physical volume and cooling demands. Of course cooling demand and heat output relate to efficiency
A big issue is density. For the sake of a lower CoG you want the KERS as dense and as flat as possible, and still be able to cool it properly. That's why Williams didn't went for it's own flywheel system, because the wheel has to be upright and that means a high CoG, also the surface area is not that big so cooling suffers. Batteries and supercapacitators are better in that respect, you can just make some holes in it and channel air through (high surface with high density) and you can mold them into a very flat shape.
For road cars on the other hand, flywheels are great. The, in my opinion, only worthwhile advantage of hybrids is regenerative braking and a flywheel system to reuse braking work for reaccelerating (60hp for5s or so) is small and light. Also in contrast to batteries a flywheel system lives longer and can be made mostly out of steel, making recycling easy.
As an aside I do find it annoying when PR pull out abstract facts with no context, those facts become irrelevant. For example, why 2 molecules hitting every 20 mins? Is that over engineered? Why not 4 every 10 minutes? Is that better or worse than comparable systems? Does it give any performance advantage?
Four molecules hitting each other (at the same time) is quite a rare occurence. Flybrid says that their racing system (either first or second generation) looses 2% a minute (seems just right), but not how efficient their CVT (quasi-CVT for second gen) is, so overall performance remains doubtful.
