Formula 2 Ground Effect Era
matt21
99
Post by matt21 » Wed Jun 22, 2011 3:43 pm
Hi!
Has anybody some additional information about ground-effect cars in F2?
Some info and pictures:
http://www.research-racing.de/formula2-1.htm
Thanks for your help!
cossie
-14
Re: Formula 2 Ground Effect Era
Post by cossie » Sat Jun 25, 2011 8:01 pm
here's a pic of the Panoz DP01 that was used in Champ Car's last year in 07, you can see the under tray right under the intakes, it was a seet car, to bad it only raced 1 year
Blaze1
36
Post by Blaze1 » Wed Sep 28, 2016 9:00 pm
cossie wrote:here's a pic of the Panoz DP01 that was used in Champ Car's last year in 07, you can see the under tray right under the intakes, it was a seet car, to bad it only raced 1 year
http://px6.streetfire.net/0001/03/28/1103082_600.jpg
Here are a couple more pictures of the Panoz DP01 floor:
I understand those are vortex generators in the entry to the tunnel. I'm not exactly sure how they work and why they are so aggressive (curve about 90 degrees to the outside!). F1 does something similar, but less aggressive though through a similar near 90 degree angle.
N44_wi
Post by N44_wi » Wed Mar 15, 2017 4:37 am
http://i18.tinypic.com/62j0yh3.jpg
https://upload.wikimedia.org/wikipedia/ ... l-crwp.jpg
I think it has correlation with the huge diffuser, they want a clean air from the front so they create a massive vortex to seal the flow
toraabe
Post by toraabe » Mon Mar 20, 2017 10:30 am
Who is online
Users browsing this forum: CCBot [Bot] and 1 guest
