JohnsonsEvilTwin wrote:So is this limit set in stone?
Well, being a cynic here, nothing in racing is "set in stone"
, for the time being, that is what has being published so far, but I'm sure there is still a fair bit of "fine tuning" (a.k.a. lobbying) going on.
I think, what has been published so far are some "headline" figures, to get the message across, that LeMans 2014 is "green" and environment friendly ( nothing wrong with that).
As far as I understand it, the underlying idea is to limit/allocate the "energy amount" used, and have (try to have) a better balance between the different concepts. For this reason, we see the different values petrol vs. diesel, because the "energy content/density" of some fuels (diesel) is higher then others Methanol for example on a volume basis (per liter).
I do think, for purely technical reasons, that there will be in all likelihood a "fuel flow" limit, which again based on technical reasons, is most likely on a time basis ( ltr. per sec) rather then on a distance basis ( ltr. per km), which would mean, that you can't safe fuel and use later more to achieve the same overall consumption.
F1 has the value of 100kg/hr published for now, I'm sure, there will be similar values x kg/l per sec/hour in the final LeMans rules. So the "endgame" is high efficiency, make as much power as you can, with the fuel you have (now).
No glory runs in Qualifying or after "saving" fuel (safetycar etc). If you manage to "save fuel" because of rain, or a long safetycar etc. you can run longer, but not make more power to compensate for this.
Now, I can be wrong off course, as I know as much (or little) as you guys, but from a pure technical point of view, you can't really write a fuel consumption on a per lap basis on a specific circuit into any form of "meaningful/water tight" technical reglement.
Keep in mind, that these cars race on other tracks as well (WEC), so how does xx l/lap in LeMans in June (temperature) correlate to a lap in Spa or Silverstone?
For this I'm reasonable sure, we will see a form of "fuel flow" restriction, and most likely on a time base, as a distance base would depend from the velocity/speed of the car as well.
Nevertheless, I think, that the ACO came out with a sensible set of rules, and it remains to be seen, how many manufacturers will take them up.
In this context, I find it interesting, that MAZDA just announced an LMP Diesel engine program, makes you wonder why this is?
On a side note, what I have not seen mentioned/discussed here so far, are the other rules changes.
LMP1's will be 100 mm smaller then now, driver needs to sit higher, and windshield/front screen size and shape will be altered as well.
