theblackangus wrote:henra wrote:Lycoming wrote:The low power is probably due to a combination of range and cost concerns with respect to the size of the batteries.
Come on!
When using available LiPo technology, an 80kWh battery would be somewhere around 30k€.
Compared to the general cost of participating in a racing series that is completely peanuts.
Problem is more related to the weight.
An 80kWh battery will be around 400 - 450kg.
At least 40-50kWh would have been desirable IMHO.
From my basic reading Lipo's are very dangerous batteries. (Looking to learn more here)
They have to be charged very carefully, and the risk of failure from impact/defects/charging issues is higher than other LiX batteries. (?)
Lipo's are used for various RC vehicles, there are videos of helicopters burning up mid air for no apparent reason. (I believed this is caused by cell charge imbalance.)
Anyone know enough to talk to the differences between battery types and why FE chose the type they use?
One of my hobbies is RC planes, and I´m using LiPo batteries for more than 10 years now. 10 years ago there was a lot of scare about LiPo batteries, and there were videos all around about batteries in flames....
But that was only a combination of two factors, new batteries and people using them as NiCd batteries. First LiPos did lack discharging rate, at 10/15C they were pushed too hard too frequently. And people was not used to soft batteries that are damaged easily in a crash (NiCd batteries have a hard case and can take a lot of abuse so people was not used to worry about the battery), so when you use a damaged battery and push it hard.... it may go in flames.
Another point was the charger. If you charge a Lipo battery at a different program (NiCd, NiMh, Pb...) it will go in flames too.
But those are normal problems for new batteries, remember I´m talking about 10 years ago. Now I don´t see a video of a Lipo in flames or hear about it for a lot of years. Now batteries can take discharge rates of up to 60C so they are much more difficult to push, and people know how to use them properly
I´m using cheap chinese Lipo batteries for those 10 years and have never had any single problem. Once I even tried to cause a shortcircuit with an old battery I was going to retire to see if it goes in flames... and nothing. I think safety of Lipo batteries did improve more than enough some years ago, now they´re as safe as any other battery, if you know how to use them there´s no problem. And my experience is with Lipos from a sector were I+D is quite low compared with automotive industry, and into that sector I´m using the cheapest batteries I can find (1/3 of first brands price) so a Lipo built for a car with the proper quality controls I think would be pretty safe
But I´ve wondered why they use LiIon instead of Lipo many times, so there must be something I´m missing...
Lycoming wrote:I believe they would be using LiFePO4 batteries. At least, that's what they should be using. Absolutely not the best power density available, but it's less prone to randomly lighting on fire, thermal runaway, etc.
LiFePo4 or A123 batteries are much easier to use than LiPo or LiIon because they can be charged much faster without any problem, and also they can be discharged to 0 volts without any damage for the battery (LiPo and LiIon should never go below 3 and 2,7 volts or they will be damaged) so they don´t need any special care.
But energy density is a bit lower than LiPo and LiIon batteries, and that´s the main problem for current batteries so LiFePo4 actually don´t solve the problem, they only are another option to LiPo and LiIon.
It´s LiS what will be a significant change, they´re suposed to duplicate energy density of current LiXX batteries
And LiO are supposed to be the next step after LiS, they should improve energy density of current batteries by a factor of 4-6. Imagine current electric cars with a battery half the weight it has now, but with double the mileage... for example a Tesla Roadster 220 kg lighter than today (1000kg) and double the mileage it can do now (700km/440miles)...
