Hope it is now more understandable how NACA duct would feed whole wing cross section.
It could be even done Renault style (like Honda Monza update)
Basic rule of thermodynamics : “there are no free lunches”. You not only are asking for a free lunch you even want to get paid to eat...manchild wrote: kilcoo, would one big additional NACA duct below original one or several smaller ones on each endplate provide enough pressure? Is that possible at all or impossible regardless on capacity of ducts?
A valve wouldn't change a thing.manchild wrote:Would one-way valve just after duct change anything?
Regarding pump... wouldn't air pump be considered as movable aero?
That includes Sea Harrier?kilcoo316 wrote:Fluidic TVC and nozzle control isn't used on aircraft, despite having an easily accessible flow of compressed air [from the engine core itself] - they simply don't perform as well as mechanical nozzles at the moment (and I don't know if that is ever going to change)
Hard to say - no way can I give an any way quantitative answer obviously...Mikey_s wrote:how about my suggestion of doing a bit of sucking to re- attach air flow onto the low pressure trailing edge...
Let’s put it this way, you are asking a NACA duct to increase the total pressure while the aim of a NACA duct design (or of any duct), that includes the selection of some geometrical parameters to adapt it to the particular case, is to minimize the pressure loss...manchild wrote: Which one is it Reca?![]()
