12.7 Tyre gases :
12.7.1 Tyres may only be inflated with air or nitrogen.
12.7.2 Any process the intent of which is to reduce the amount of moisture in the tyre and/or in its inflation gas is forbidden.
air [ɛə]
n
1. (Chemistry / Elements & Compounds) the mixture of gases that forms the earth's atmosphere. At sea level dry air has a density of 1.226 kilograms per cubic metre and consists of 78.08 per cent nitrogen, 20.95 per cent oxygen, 0.93 per cent argon, 0.03 per cent carbon dioxide, with smaller quantities of ozone and inert gases; water vapour varies between 0 and 4 per cent and in industrial areas sulphur gases may be present as pollutants
marcush. wrote:how much magnesium is in current wheel alloys? I´d think the potential for self igniting is rather low.Magnesium itself is only igniteable in ´form of powder or chips..so maybe the grinding of the wheel on the hub or more so the carbon brake disc is exploding when subject to the loads in the accident?
Muulka wrote:marcush. wrote:how much magnesium is in current wheel alloys? I´d think the potential for self igniting is rather low.Magnesium itself is only igniteable in ´form of powder or chips..so maybe the grinding of the wheel on the hub or more so the carbon brake disc is exploding when subject to the loads in the accident?
Magnesium is highly flammable in the form of a metal strip at least, and I have seen videos of a rally car being set alight by its magnesium wheels. It's aluminium that you're thinking of probably.
hardingfv32 wrote:1) Based on the weight of the F1 wheel I have it is 100% mag.
Ciro Pabón wrote: Few persons are free of DHMO in their bodies ...
DaveKillens wrote:The FIA technical regulations for 2011 state :12.7 Tyre gases :
http://argent.fia.com/web/fia-public.nsf/055CFD424959A061C1257870003A02F0/$FILE/1-2011%20TECHNICAL%20REGULATIONS%2008-03-2011.pdf
Users browsing this forum: Twitter [Bot], vdemeter and 4 guests
