Next year exhausts
Post Reply
Javert
Next year exhausts
Where they would exactly be located ?
What aero function would they have ? Off-throttle blowing will be useful, will be useless or will be banned ? How much time would be lost ?
HampusA
Re: Next year exhausts
Not sure but i think i read that they will revert back to the old style where the exhaust exits on top of the sidepods/rear section.
The truth will come out...
Giblet
I'm pretty sure the off throttle blowing is gone for next year.
Assuming that is the case, I believe that advantages gained from placing the outlets somewhere for as little drag penalty as possible will outweigh blowing the diffuser on throttle. The off throttle blowing was about adding more downforce in the slower corners and under breaking, but with the volume of air moving past the diffuser at any reasonable speed i don't see the engine adding very much volume in relation.
raymondu999
Periscopes are back no? They'll feed into the empty space between the rear and beam wings. Ie clean air. No use for off throttle blowing though I believe it's not "banned" as such, just useless
失败者找理由,成功者找方法
Javert
So like this ?
hecti
Check out this article by scarbsf1:
http://scarbsf1.wordpress.com/2011/06/1 ... re-banned/
it explains everything
Post Reply
