raymondu999 wrote:I wonder. I think there are several designs that have steered quite well clear of this issue. Renault probably has, seems to just be aimed out under the rear wing and above the crash (into free air?) and Red Bull maybe? Though I'm not sure of that.
A Technical Directive was issued that stated:
"that any exhaust designs that reingest or redirect exhaust flow for principally aerodynamic reasons will not be permitted."
Just_a_fan wrote:@Coefficient
My view is that McLaren are trying to mimic the edge sealing of the diffuser as with last year's EBD. The EBD is designed to help prevent the dirty air from the tyre ruining the flow under the diffuser. In effect it acts as a skirt to seal the diffuser and make it work harder.
The thing about the diffuser is that it's job is to get the flow below the floor to meet the flow above in the nicest way possible in order to reduce drag and improve efficiency. Ironically, this works best when the pressure difference across the diffuser is low. By having a region of high pressure above the diffuser you actually reduce its efficiency.
Look at the designs of the cars - they are all designed to get air to flow over the top of the diffuser - this flowing air will reduce the pressure above the diffuser and so make it more efficient. If you wanted to maximise the pressure difference across the diffuser you would have bodywork between the rear wheels in order to have a volume of still (and thus relatively higher pressure) air in this region. The teams don't do that - they want air to flow over the top of the diffuser. And flowing air has less pressure than still air.
Coefficient wrote:Just_a_fan wrote:@Coefficient
So, are they attempting to aim the exhaust plume between the edge of the diffuser and the Wheel assembly and also hoping the exhaust flow will augment the flow over the diffuser's upper surface?
I'd be interested to know:
1. How quickly the exhaust plume reverts to a lower energy state
2. Is the oncoming airflow over the car enough to assist the Exhaust plume to maintain adequate energy?
3. Would a significant tail wind have a disrupting effect on the overall principle?
Users browsing this forum: No registered users and 11 guests
