Sauber Front Suspension
hardingfv32
32
What is the link connecting the what is usually the ends of the torsion bars?
Brian
kebab
Re: Sauber Front Suspension
It looks like a temporary link rather than a permanent. May be it's used for setup the torsion bars
Crucial_Xtreme
404
There's a strut between the torsion bars.
kebab
a strut bar is a possibility but isn't that end of the torsion bar supposed to be fix?
small pic ,but Renault R31+ R30 had it as well.discussed this back then in the car thread .
R29 did not have it ,but I think R28 or 27..
DaveW
239
A neat way to decouple heave/pitch and roll stiffness & to preload the springs, perhaps.
DaveW wrote:A neat way to decouple heave/pitch and roll stiffness & to preload the springs, perhaps.
that was my thought
Jersey Tom
If you have a solid bar there preventing your torsion bars from rotating in opposing directions, your wheel rate (not ride rate) in heave would be infinite, would it not? Would it not lock out the suspension travel?
I'd think that would be a setup tool.
the reanult has the same and it´s definetly not for setup
DaveW
239
Jersey Tom wrote:If you have a solid bar there preventing your torsion bars from rotating in opposing directions, your wheel rate (not ride rate) in heave would be infinite, would it not? Would it not lock out the suspension travel?.
I suspect you have misread the layout, JT. What can see is the (notional) fixed end of the torsion bar. The other (hidden) end will be attached to the rocker. It follows that roll motion will not be restrained by the torsion bars, but it will be a separate (hidden) bar (probably quite a soft one). The ride height (preload) will be set by then length of the tie rod (probably has a length adjuster)
Jersey Tom
I'd have to see the thing, since it's not a suspension topology I usually work with!
Fixed end? So with the link not there, if you were to put one wheel in jounce that splined end would not rotate?
If it does, then the link in there would not affect roll, I agree.. but it would lock out your axle jounce.
I would have thought it a handy way of setting a nominal axle displacement or just preventing the wheels from going full droop with the car on stands even without main springs in.
Tim.Wright
330
I think Dave is correct.
In heave, the ends you see are locked and the other ends (at the rocker) rotate like a normal torsion bar.
In roll the linked ands at the front follow each other (and their respective input sides) and as a result the torsion bars dont twist.
Seems a quite simple method of completely decoupling heave and roll.
Tim
Jersey Tom
Ahh OK. I see. So ordinarily that visible end of each bar would be fixed. By removing that constraint and putting the rigid link in place, you fix the ends of the bars for axle jounce but completely disengage the main springs for any amount of roll stiffness.
That's slick. I like that.
GSpeedR
26
What mechanism will resist roll on this setup?
Edit: I assume something not shown in the pictures(?).
Jersey Tom
They still have ARB's activated by the rockers. I believe that's out of sight in these pictures.
Might have to go up to a 2 5/8" sway bar to get the roll stiffness with zero contribution from the main springs...
