I have searched the thread with " Coanda" but cant find the topic
how much power does it drain from the engine as compared to non Coanda-style exhausts
I called the topic this as its about the coanda exhaust and people may want to talk more than just the power of ithollus wrote:What about adding the word "power" to the title, then, so that the next person to search like you did can actually find the right topic?
Mods?
Not sure ion terms of power, but on Friday Raikkonen was 3Km/h down on top speed compared to Grosjean. Of course it could be due to setup as much as to the exhaust.
Actually, Lotus have said, both by means of Raikkonen and the team's technical director James Allison that it takes away some engine power. It's maybe not the case for all configurations, but it has to do with the length of the exhaust, and maybe also the exhaust channel wherein it exits, instead of a more free stream of air.skgoa wrote:The answer is "none."
^The right explanation IMHOmarcush. wrote:the Coanda exhausts use a smaller exhaust tip diameter -increasing the speed of exhaust flow at the exit .This is not the optimum setup for maximum power .
But on the other hand it sure bumps the torque at lower rpm as well ..so overall it might cost the odd km/h in terminal speed if any .
Would the minimum radius rules allow something like that winglet in the McLaren anywhere mid sidepod? Now I don't dare to say not...Carlos (in 2006) wrote:This is 29 pages long, and it may be familiar material -- but it may have some application or interesting value:
http://www50.dt.navy.mil/reports/CC.pdf
Just an idea -- Does the "Coanda-effect circulation control to low aspect ratio wings" have any application to underbody "flow control" or wing design? I was reading a little about it and wondered if anyone else had
an idea about possible applications.
Again simple questions with not so simple answers.....hardingfv32 wrote:1) Opening the exhaust into a low pressure zone is helpful. Do the current Coanda exhaust configurations promote low pressure at the exhaust upening?
2) I can not say that I have noticed that the exhaust chokes down for the Coanda systems. What is the benefit of 'increasing the speed of exhaust flow at the exit'? Does it help with flow redirection?
Brian
Firstly, I have been led to believe the thermal energy (temperature) of the air stream is less critical than its kinetic energy (velocity) for use in this situation, which is the creation of a vortex at the diffuser interface that is primarily to seal the low pressure diffuser area. I think it is important to that this is what the exhaust blown diffusers and Coanda exhaust are actually trying to do, that is seal the diffuser area from pressure and turbulence influences such as tyre squirt which is a BIG factor to increase its efficiency.olefud wrote:It seems that using the exhaust for Coanda doesn’t per se compromise power, only the flow control and enhancement to direct the exhaust. What would a substantially enhanced hot air flow from the brakes do for aero?
It’s sometimes overlooked that brake heat is primarily rejected as radiant energy. This is because radiant heat is rejected to the fourth power of the difference in delta absolute temp. I’ve been working on a means to substantially enhance convection cooling of the brakes which develops heated air at the brakes in a nicely controlled heated flow (incandescent particles in the stream). With much more energy in the convection cooling flow, the rotor runs cooler and the radiant cooling is diminished. This convection stream at the wheels is nicely positioned and occurs at a favorable time. My brake dyno data is with cast iron rotors, but with a few fudge factors it maybe can be guesstimated for carbon disks
If I could provide such a heated air stream, could you aero guys do anything with it?
