I was wondering that while following under dirty air, downforce is reduced, as a consequence cornering speed will also be reduced. As this speed reduces since cornering forces are less, tyre degradation should also decrease accordingly, why is this not the case.
For the reason of sliding, driver will be pushing the car up to the extent it won't spin. So for the clean air sliding will also increase at a higher speed as compared to the car cornering in dirty air.
So what is the phenomenon of tyre degradation in accordance with dirty/clean air?
