Aero grip vs. mechanical grip (and low profile tires)
DaveW
DaveW
239
Re: Aero grip vs. mechanical grip (and low profile tires)
Milliken "Camber Car", perhaps - but I wasn't advocating that solution in my previous post
Greg Locock
Greg Locock
233
Tim.Wright
330
That DAX suspension seems to add a lot of complexity to effectivaly replicate the kinematics of a beam axle.
trinidefender
trinidefender
317
Tim.Wright wrote:That DAX suspension seems to add a lot of complexity to effectivaly replicate the kinematics of a beam axle.
A beam axle without the both unsprung weight and what seems like the disadvantages of not being able to change camber at all. According to the article this system can still change camber if desirable in roll profiles simply through the use of unequal length wishbones. Am I correct?
Greg Locock
Greg Locock
233
I think both Milliken's car and Dax are trying to solve a problem that radial tires don't really have. Crossplies had about 4 times as much camber thrust as radials.
theTTshark
theTTshark
Greg Locock wrote:or the dax suspension http://locost7.info/mirror/dax.php
I think they were also missing a big point...The conditions the tires see at turn in is much different then mid corner.
J.A.W.
J.A.W.
109
Greg Locock wrote:I think both Milliken's car and Dax are trying to solve a problem that radial tires don't really have. Crossplies had about 4 times as much camber thrust as radials.
The Dax appears to be somewhat similar in concept ( turned 90`) to this racebike rear suspension tried some 40 years ago..
http://www.3cyl.com/mraxl/tunerwisdom/parallelogram.htm
Do any of the Caterham 7 - 'De Dion' type rear suspension units - allow for a negative camber set-up, fixed or adjustable?
