hello,
if One has to design a vehicle.....i think the first step in the process is to determine the amount of wheelbase and track width to run.....is there any specific methodology to come to the right numbers???......
I do know that a longer wheel base has more wt transfer longitdinally..and a wider track does the same laterally. So obviously this the basis for designing or getting the right wheel base and track......
what methodology or philosophy will u guys use if u r assigned to find out the right wheel base and track????
