Photo Comparison Williams FW30-Toyota TF108
Post Thu Jan 31, 2008 2:43 pm
I still need some FW30 high res pics but i managed to prepare the first set of comparison images . The 2nd set is on the way .
After Williams launch i am planning to post the same sets including William's new Livey .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
Post Thu Jan 31, 2008 7:15 pm
So, no realistic similarities to show codevelopment around the identical engines...
Thank you bar555!
Conceptual
Post Fri Feb 01, 2008 6:48 pm
1.Different exhausts
2.Different Diffuser
3.Williams FW30 does not have shark tail fin
4.Williams FW30 has a gearbox radiator outlet
bar555
Post Fri Feb 01, 2008 7:55 pm
Grat thread =D> but in the rear view, the williams car is not FW30 but FW29B, becouse the FW30 has an opening at the back of the enginecover and other things, here is the best picture i coul find of the FW30 from the back
tomazy
Post Sat Feb 02, 2008 7:23 am
You are correct , my mistake :( , i redited the post
bar555
Post Sat Mar 08, 2008 2:22 pm
NOSE CONE TRANSITION IMAGE
bar555
Post Sat Mar 08, 2008 3:22 pm
looking at the pics, the williams rearend seems very similar to the f2007's. i don't know, does anyone else see that?
allan
Post Sat Mar 08, 2008 6:51 pm
Thanks bar555 another excellent post.
Looking at the difference between the Williams and the Toyota's cockpit side protection. The Williams has nicely sculptured undercuts between the cockpit and the side protection to channel the airflow, while the Toyota looks like no real thought has gone into them with regards to what and where the airflow is going to go.
Looking at bar555 other posts, the cockpit protection on the McLaren, Ferrari and Renault are also deeply undercut, like the Williams.
Project Four
Post Sun Mar 09, 2008 3:48 pm
Still, the Williams has the biggest undercut, between the cockpit and the side protection!
BB_BOSS
Post Sun Mar 09, 2008 9:48 pm
Look at the rear view of the FW30 at the endplates you see a small cut in the rear wing.
Post Mon Mar 10, 2008 10:14 am
bar555
Post Sun Mar 30, 2008 1:30 pm
bar555
Post Wed Jul 02, 2008 6:07 pm
bar555
Post Wed Oct 29, 2008 6:12 am
TOYOTA TF108
WILLIAMS FW30
bar555
Post Wed Oct 29, 2008 12:38 pm
Note that you should be careful when point out (1) as the power steering plumbing. While it's all a bit tangled in between, the two largest cylinders containing fluid are in fact the mast cylinders of the brake system.
:arrow: http://www.f1technical.net/articles/2
Tomba
Next
Who is online
Users browsing this forum: CCBot [Bot], rscsr and 5 guests
