Can someone please explain how ride height (not including ground effects) and track width effect grip?
Does a higher ride height provide more grip because you get more weight transfer?
What about track width?
Regards,
Not always true. Haven´t you driven a kart in the wet?Jersey Tom wrote:Load transfer = bad for grip.
Proof? Source? Other than maybe if they're running softer springs in general and just to offset for how much aero is gonna compress everything.Belatti wrote:Not always true. Haven´t you driven a kart in the wet?
Even in F1 ride hieght is increased for wet weather.
No.ICA wrote:Lets say that we have a narrow front end, does this make a chassis 'sharp' or 'twichy'?
So, you havent driven a kart in the wet!Jersey Tom wrote:Proof? Source? Other than maybe if they're running softer springs in general and just to offset for how much aero is gonna compress everything.Belatti wrote:Not always true. Haven´t you driven a kart in the wet?
Nothing about it being wet (that I can think of) makes an axle want more load transfer for better grip. There may be other reasons, but they're going to want to keep it as low as they can get away with.
Sounds like BS, to be honest.. and that guy is mixing up terminology. Not exactly a reputable source (not that there really are any).Simple: "by raising the front ride height, you effectively raise the center of gravity in the kart and will be increasing the side bite on the tire, making it grip harder. If you go too high however, the raised CG will make the kart "bicycle" or pick up its inside wheels."
I clearly remember Brundle saying that wet weather tyres have slightly larger diameter hence extra ride height.Jersey Tom wrote:Proof? Source? Other than maybe if they're running softer springs in general and just to offset for how much aero is gonna compress everything.Belatti wrote:Even in F1 ride hieght is increased for wet weather.
Yes, but soft springs allow riding over bumps and curbs w/o loosing grip altogether.ICA wrote:Why do softer springs give more grip? dont soft springs increase load transfer?
Regards,
How would you define "grip"?Is it the friction factor*weight?Or just the situation,when car has a feel of more grip?Or sth. else?ICA wrote:Can someone please explain how ride height (not including ground effects) and track width effect grip?
Regards,
Soft springs have nothing to do with steady-state load transfer. That's a function of lateral acceleration, track width, and CG height. Softening springs while keeping everything else the same WILL increase chassis roll.. but big deal.ICA wrote:Why do softer springs give more grip? dont soft springs increase load transfer?
Regards,
Yes, agreed. I swear it works, but the reason? Don't know. What I know is that everybody and his dog rides with rear axle as high as possible (it has only two positions, btw) and raises the front axle in the rain (this can be graduated, unlike the rear). I do and I really like driving in the rain. I think I have an advantage because of my height. You lose a little bit of braking, but, also in the rain, you want to stomp on the brakes, another thing in karts that goes against the full-racing-car theory, btw.Jersey Tom wrote:Sounds like BS, to be honest.. and that guy is mixing up terminology. Not exactly a reputable source (not that there really are any).
OMG. I'm getting dumber by the minute. I swear I thought you both were talking about the racetrack width... damn english.Jersey Tom wrote:For example, suppose you had a car that was SUPER wide. As wide as the race track! In theory you'd have real great grip on a skidpad. However, the width of the thing would mean your racing line would be stuck going around the center of the track. With a narrow track width, you can take a much broader arc through the corner.
Grip, I think, is the amount of lateral force a tyre can develop before sliding.fatburner wrote:How would you define "grip"?Is it the friction factor*weight?Or just the situation,when car has a feel of more grip?Or sth. else?
Except the deflection isn't what matters. The spring constant is what matters in terms of lowering tire load variation, and you don't change that (much) by putting on extra load.Krispy wrote:So here are my thoughts relating raising the CG in a Kart to using softer springs on a race car.
With a Kart most (nearly all?) of your suspension travel is in the tyres right? By raising the CG you are increasing the lateral load transfer and thereby putting more force on the outside tyre. The tyre is effectively your spring and has its own spring constant. With more load it deflects more (the same way changing to a softer spring and the same CG would cause more deflection at the spring in a given cornering maneuver).
To people with Karting experience: Do you find that different tyre pressures are favored in the rain? Are they higher or lower than the setup you would normally use on a dry track?
