ive noticed drivers adjusting there brake bias on certain corners.
why?
what are the advantages?
whats better for the hard braking slow corners?
thanks.
marcush. wrote:I used such a mechanical brake delay valve 10 years ago already ...made in USA by Stewart components..itwas a simple device that only retarded the rise of the line pressure but not the pressure itself...simple bleed piston with spring actuation opening the port .
timbo wrote:However, it is almost impossible for driver to precisely control balance WHILE braking (however, it seems like some used throttle to do just that). But @ espionage hearing 2007, it was told that Ferrari used simple mechanical system to delay the onset of rear wheels braking.
timbo wrote:marcush. wrote:I used such a mechanical brake delay valve 10 years ago already ...made in USA by Stewart components..itwas a simple device that only retarded the rise of the line pressure but not the pressure itself...simple bleed piston with spring actuation opening the port .
That's probably very close to what Ferrari used.
autogyro wrote:timbo wrote:marcush. wrote:I used such a mechanical brake delay valve 10 years ago already ...made in USA by Stewart components..itwas a simple device that only retarded the rise of the line pressure but not the pressure itself...simple bleed piston with spring actuation opening the port .
Back in the 70s they had a brake compensator valve on the early mini Cooper S.
We used to modify it and make it driver adjustable inside the car.
raymondu999 wrote:We often see drivers deciding on a brake bias, then they decide to brake later/harder, and turn the brake bias. I wonder which way they turn the bias...
varley16 wrote:ive noticed drivers adjusting there brake bias on certain corners.
why?
747heavy wrote:@ markus
Hi Marcus,
I´m not sure Ferrari wanted to/has retarded braking on one axle with their system.
I think it was a dynamic change in brake bias during braking.
If you don´t mind to share, why would you want to retard (delay) pressure built up in one circuit?
Thanks !!
Users browsing this forum: flmkane and 10 guests
