Red Bull RB11 Renault
maxxer
maxxer
Re: Red Bull RB11 Renault
They say they changed supplier this year ,must have changed brake supplier after the testing then :
http://formule1.nl/media/uploads/media_ ... 614.39.jpg
And Seb never liked them :
http://www.brembo.com/en/car/Racing/Bre ... 0fame.aspx
They are still using Brembo calipers IMO. They just changed the disc manufacturer it seems.
Facts Only wrote:
The pre homologation dev' engines had 9 lambda probes, it's still the primary measurement.
What in God's green earth do you do with 9 lamba probes at the track? Nope... I can see using that on the dyno to calibrate each cylinder. and especially if the teams are using cylinder de-activation... but I cannot see any reason to use 9 on the track. My common sense is telling me that cannot be true. I would believe you if you said 9 EGT probes. The engines are turbo-charged and back pressure and reversions is a serious effect in these engines. The temperature difference across the turbo charger is important. I am going to say it is EGT unless you can prove otherwise.
l4mbch0ps
l4mbch0ps
PlatinumZealot wrote:I am going to say it is EGT unless you can prove otherwise.
e]
Well there you have it folks... burden of proof is on you now I guess? hahaha
l4mbch0ps
l4mbch0ps
Yes... haha... he set him self a high standard from before.
He still owes me some facts from a previous convo... 8)
SectorOne
4 centimeters??
As if anyone can eyeball a 4cm difference even if they did change the nose. haha.. AMuS never ceases to amaze with their predictions...
FW17
168
Maybe that Center stub will be gone to a flatter section
maxxer
maxxer
According to the team thread they are using Carbone Industrie now and it used to be Brembo.
But it seems they can choose between both for each race or driver? As i found an article about LH changing his discs to another manufacturer after having a brake failure in qualifying at last years German Grand Prix.
http://www1.skysports.com/f1/news/12475 ... his-brakes
SectorOne
PlatinumZealot wrote:4 centimeters??
I messed up the tweets, that was for STR. The 4cm most likely came from Key himself.
Meaning the new nose for STR will be a Mercedes/Lotus type nose.
Updated the tweet and it does seem like every team wants to run a Merc-nose.
Seems to me the thumb nose is a compromise, the blade nose is a cheap and secure crash test nose and the log nose of Sauber is a "end of the world and still be alright" type nose.
there has been a somewhat similar version posted before, but i really dig this one and the professionalism in it.
this looks awesome
SectorOne
GoranF1
GoranF1
155
James Roberts ‏@JRobertsF1 18m18 minutes ago
Just spoke to Ricciardo and he says that Red Bull will be returning to the Brembo brakes this weekend after they'd been trialling the Hitcos
edit: can someone explain please how you paste a whole tweet here please?
zorog
zorog
just put the
Code: Select all
[tweet][/tweet]
codes around the twitter url
in your case
Code: Select all
[tweet]https://twitter.com/JRobertsF1/status/586096748604612608[/tweet]
here is the result: https://twitter.com/JRobertsF1/status/5 ... 8604612608
