Recent Oil Tests
hardingfv32
hardingfv32
32
Recent Oil Tests
Could the engine oil have properties that reduces combustion chamber detonation? Is that chemically possible?
Brian
DiogoBrand
73
Re: Recent Oil Tests
I really think it's unlikely that the engine oil would somehow alter combustion characteristics since they (ideally) don't interact.
riff_raff
riff_raff
132
In theory, engine oil could provide a small improvement in an engine's detonation limit. Lube oil is used to help cool the underside of the piston crown. If you came up with some magical lube oil that had a super high specific heat value, it could provide better cooling of the piston crown. Which would improve the detonation limit of the engine, all other things being equal.
A: Start with a large one!"
