That is correct. These are called thermal barrier coatings or TBC's. Usually these are Yttria/zirconia based and applied with flame spraying or plasma spraying of ceramic powders..trinidefender wrote:Some of the commercial (power generation) gas turbines use steam cooled blades, how about that for an idea.
I can't remember correctly but on avaiaton based gas turbines isn't the most common solution for the high pressure section single crystal alloys with a coating (maybe ceramic coating)? Going to break out of a few of the aviation gas turbine design books I have lying around, probably not the most up to date material though.
I know these days ceramics are heavily used in the combustion chamber of gas turbines, one place they are definitely worth it!
I think they are also used in F1. If you look at the picture of the mercedes exhaust below you can see a whitish shine which suspiciously looks like a TBC. I know they have also been testing them on exhaust manifolds but one of the concerns is spalling and coating pieces ending up in the turbine. So I'm not sure whether they are actually used in front of or inside the turbine housing.
I think the latest generation of SiC composites are absolutely beautiful. But the process of making them does not really lend itself to making the fine structures needed for turbines.Brian Coat wrote:Thanks for the comments/ideas/corrections about ceramics turbo components.
I doubt it is worth the cost but impact resistance has been overcome using matrix composite techniques eg SiC/SiC? And I think techniques for achieving the desired geometry exist but again very costly.
Compare that to sintered ceramics. The process which is normally used to make silicon nitride turbines is by injection molding. The powder is mixed with a binder. The mixture is then injection molded like a normal plastic component. The binder is carefully burned of and the shape is sintered. If you compensate for the shrinkage (up to 50%) and use support structures to prevent sagging you can make a shape with good surface finish (minimal rework) in one shot.
