2021 Emilia Romagna Grand Prix - Imola, Apr 16 - 18
dans79
267
Re: 2021 Emilia Romagna Grand Prix - Imola, Apr 16 - 18
It's almost unbelievable how much ground he made up down the strait. He took 9 tenths out of Ric.
197 104 103 7
dans79 wrote:
23 Apr 2021, 16:16
I think the cars would have struggled had the DRS activation point not been moved. They wouldn't have been able to get close enough to have a go in to the first left hander otherwise. We could see on that clip how even with DRS for almost the whole straight, the Mercedes needed to be about 7-8/10ths behind to have a sniff. 9/10ths was too far back against Leclerc and Norris.
dans79
267
Just_a_fan wrote:
23 Apr 2021, 16:50
I think that's mainly because they were faster.
I mean Danny finished over 24 seconds behind Carlos, Stroll was even further back. Carlos seemed to have a hard time getting the power down through the last 2 corners. Charles had DRS on Norris, and then as soon has he lost that Lewis got by. Lando was the hardest, and I assume that was because the mclaren had good strait line speed if memory serves.
197 104 103 7
nacho
nacho
DRS was powerful here this year, I think they extended it for 2021.
LHamilton
LHamilton
NathanOlder wrote:
23 Apr 2021, 08:56
LHamilton wrote:
23 Apr 2021, 04:01
Looks like Perez did use more kerb than Verstappen during their respective Q3 run. So there might be something to it.
Verstappens mistake in the second corner lost him quite a bit I must say.
https://www.youtube.com/watch?v=zhEMuDNGy7I
Perez used more ?
I see they were using the same through
Tamburello, entry and mid, but max goes wider on exit and loses time.
Villeneuve same amount on way through but Sergio uses a tiny bit more of the exit curb.
Tosa they use the same.
Piratella they use the same.
Acque Minerale Max used more on exit (thats a very nasty curb)
Variante Alta Max used more on enty , mid and exit (they are the most brutal curbs on the circuit)
Rivazza both drivers use the same amount
So I see Max using more overall and more on all the nasty curbs. So I don't believe he held off the curbs in qualifying.
Go and rewatch the video, because this ain't correct.
Rivazza, Perez used more on entry kerbs. Both of them.
Acque Minerale Perez used more on entry curb up towards Variante Alta.
Piratella Perez used more on entry kerb.
Some of the others are minor ones, but the ones listed above is quite substantial.
Looks like there are points where Max tries to avoid the higher kerbs (entries) which are the ones that unsettles the car the most. The exit kerbs probably aren't that bad, even though they are rough. Because as you said, in the Tamburello corner they take similar kerb, but Max is the one that got an oversteer moment and lost time. But yeah. Ifs, buts and maybes
Can't see Perez outqualify Verstappen to many times if Verstappen is hailed to be this 'outworldly' driver. 3-4 times I'd say, when Max has his off days. Perez went 5-15 against Ocon in 2018 I believe. And on average something like 8-12 against Hulkenberg.
NathanOlder
LHamilton wrote:
23 Apr 2021, 17:32
NathanOlder wrote:
23 Apr 2021, 08:56
LHamilton wrote:
23 Apr 2021, 04:01
Perez used more ?
Can't see Perez outqualify Verstappen to many times if Verstappen is hailed to be this 'outworldly' driver. 3-4 times I'd say, when Max has his off days. Perez went 15-5 against Ocon in 2018 I believe. And on average something like 12-8 against Hulkenberg.
I have to disagree, the entry curbs are nowhere near as back as the sausage exit curbs. Acque Minerale exit and Variante Alta are the killer ones and Max uses more.
GoLandoGo
Lewis v2.0
King George has arrived.
TimW
TimW
36
Given that it is the pullrod eye bearing, it will be front suspension performance that is affected. I'd guess that is less of an issue on turn exit.
The most isee is a sticky bearing.. Probably more damping than normal.
Goes to show that the RedBull is dominant in qualifying this year. A sticky pull rod and a big mistake off the track and it was within hundredths for pole.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
mzso
mzso
That left wheel has a fair bit more angle on it, right?
Is that typical?
dans79 wrote:
23 Apr 2021, 17:05
Just_a_fan wrote:
23 Apr 2021, 16:50
Yes, but he got past each of the team mates easily enough. Which adds an interesting variable.
siskue2005
70
mzso wrote:
24 Apr 2021, 00:45
Is that typical?
Pro and Anti Ackermann suspension
viewtopic.php?t=16957
Unf
dans79 wrote:
23 Apr 2021, 16:16
Incredible overtaking... with magic button called "DRS" which cause that guy in front can do literally nothing to defend himself. Rubbish.
Yep, that's the reason so many still want DRS gone.
foxmulder_ms
foxmulder_ms
haha lol.. DRS is the best thing happened to F1 after Lewis ;)
Sieper
73
I agree, DRS is needed it has brought so many interesting battles. Even these overtakes weren’t that easy imho. Without DRS we would see way less fights.
