dren
226
Re: Honda Power Unit
That's assuming they were running the full 160hp at the MGUK in the first place.
All the PU manufacturers are able to implement brand new engines at the start of 2015. The unfreeze is just to allow the manufacturers to add updates through the year.
Honda!
xpensive
xpensive
214
dren wrote:That's assuming they were running the full 160hp at the MGUK in the first place.
Not xactly, there is a certain percentage of the engine, shrinking by year I believe, that is allowed to be changed.
xpensive wrote: Not xactly, there is a certain percentage of the engine, shrinking by year I believe, that is allowed to be changed.
With the Token System 48% of the 2014 PU can be changed for 2015.
xpensive
xpensive
214
Oh boy, will there be discussions of which 48 percent of what, mama.
Sasha
Sasha
63
Honda is a little behind on their PU because they had to go in a new direction after seeing the Mercedes PU.Their original design was like the Renault/Ferrari design.Honda's new design is focusing on being more compact,lighter with bigger turbo.
Everybody was shocked when they saw the Mercedes PU for the first time!They went totally the different route than the others(very compact and total power over no turbo lag,the extra electric power solved the turbo lag problem).
xpensive
xpensive
214
Sasha wrote:Honda is a little behind on their PU because they had to go in a new direction after seeing the Mercedes PU.Their original design was like the Renault/Ferrari design.Honda's new design is focusing on being more compact,lighter with bigger turbo.
And aren't you the smart one, depending on how much you know about the first house, the second house you build is always better.
xpensive wrote:
Thunders wrote:
It's pretty straighforward, every Part you change costs a specific ammount of Tokens, the Engine Manufacturers only have a set ammount of Tokens they can spend. The Ammount of Tokens they can spend gets smaller every Year. There was a List somewhere that showed it.
Holm86
245
http://www.fia.com/sites/default/files/ ... -06-29.pdf
Look at page 88.
Thanks Holm for linking.
564
xpensive wrote:So with the ERS limited to 160 Hp, the 10% increase of the PU must come from the ICE, right?
This means the ICE going from typically 600 Hp to 680, yeah right, how would that happen?
Not necessarily. For example if the current PU sees 600 from ICE crank, 80 from MGUH the max continuous output is 680. For short term only the MGUK can borrow from the ES to make 600 + 160 = 760. If MB can improve the continuous output by 68 (10%) to 748, it could consist of 638 crank and 110 MGUH. The extra from the MGUH is still very useful in race conditions.
xpensive
xpensive
214
Didn't xactly get the logic of the above, but fact of the matter is that the max output of the PU is the ICE plus the MGU-K,
regardless how you slice or dice it. The MGU-K is limited to 160 Hp and the ICE fuel flow is limited, why any increase in
maximum horsepower must at the end of the day come from an increase in efficiency in the ICE.
trinidefender
trinidefender
317
xpensive wrote:Didn't xactly get the logic of the above, but fact of the matter is that the max output of the PU is the ICE plus the MGU-K,
That 160 hp that the ERS-k can produce that you are referring to can only be used for ~33 seconds per lap. This is because the rules regulate the amount of energy that can go from the energy store (battery) to the ERS-K. However there is no limit on how much energy can be sent directly from the ERS-H to the ERS-K. Therefore if you can have an ICE that can produce the same hp as the competitors yet provide more electrical energy from the ERS-H then you can send all the extra energy straight to the ERS-K. To all intents and purposes you have more power over the whole lap instead of only part of the lap.
xpensive
xpensive
214
Oh, I had no idea... :o
J.A.W.
J.A.W.
109
Thanks for the cogent post, T..
564
If you look at the list, most are items that probably don't need modification to catch up to Mercedes.
