mclaren113 wrote:
Guys, I think the slot on the side of the front wing has something with the flexibility!
this is the link for the pic:
http://www.flickr.com/photos/f1photos/5 ... otostream/
Tech Regulations 2011, article 3.15 wrote: Aerodynamic influence :
With the exception of the driver adjustable bodywork described in Article 3.18 (in addition to minimal parts solely associated with its actuation) and the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance :
- must comply with the rules relating to bodywork ;
- must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom) ;
- must remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances.
No part having an aerodynamic influence and no part of the bodywork, with the exception of the skid block in 3.13 above, may under any circumstances be located below the reference plane.
Tech regulations 2011, article 3.17.8 wrote: In order to ensure that the requirements of Article 3.15 are respected, the FIA reserves the right to introduce further load/deflection tests on any part of the bodywork which appears to be (or is suspected of), moving whilst the car is in motion.
Are you referring to the strake on the nosecone? That is for making the nose cone/wing stay profile legal. If the stays are wider than the nosecone, they add a line of material there to widen the nosecone. Mercedes have a similar detail.mclaren113 wrote:this is the link for the pic:mclaren113 wrote:
Is it 100kg per side? I can't find any reference to the test in the regs. If so, this is another lapse of judgement on the part of the FIA.hollowBallistix wrote:surely the only problem with the FIA test with putting weight onto the end plate & measuring the flex is the fact they are not putting enough weight on ! 100kg surely is not enough ?
This is exactly what I have been saying is why you can't setup any hard and fast dimensional measurement on a moving car. the data is far to noisy.avatar wrote:
Appologies for the slight irrelevance, but its yet another dynamic your account for when atrempying any meaninful measurement.
