Infiniti Red Bull Racing 2015
FoxHound
55
Re: Infiniti Red Bull Racing 2015
djos wrote:
Have a look at reliability and you'll see that the Renault PU was by far the lest reliable of the 2 PU's.
Ps good work ignoring lotus, using them to compare against Sauber would be a much better comparison as both are generally scraping the barrel for funding, Toro Rosso isn't.
Djos, (politely)
Hot stepping from performance to reliabilty is BS.
What point is it to have a reliable motor that garners you less points than an unreliable motor.
Its not an argument bro.
JET set
djos
113
you not agreeing with me doesn't mean my opinion is invalid.
"In downforce we trust"
Cold Fussion
Cold Fussion
93
FoxHound wrote:
SectorOne wrote:Maybe the FIA should declare that Honda and Renault gets a whole season with unlimited tokens.
Totally unfair to Mercedes and Ferrari but that would be one way to get them back on their feet quicker.
Personally I feel its better to keep the token allocation as it is. BUT, allow Renault and Honda to implement the changes outside of the 4 engines a season rule.
For instance, Renault have a current issue, allow the fix of the part without incurring a penalty on the engine as a whole.
Its the way forward.
How is that any better than unlimited tokens but only 4 engines?
JordanFiveOh
JordanFiveOh
FoxHound wrote:
Juzh wrote:
Kingshark wrote:In 2014 the worst engine on the grid was Ferrari
Nope. Debatable.
Nope, Factual.
2 Renault engined cars finished above the factory Ferrari's.
And if we have a look at the like for like comparison that alot of people love to do...
Ferrari customer Sauber 2013 results: 57 points and 7th in the standings.
Renault customer Torro Rosso 2013 results: 33 points and 8th in the standings.
Ferrari customer Sauber 2014 results: 0 points and 10th in the standings.
Renault customer Torro Rosso 2014 results: 30 points and 7th in the standings.
Toro Rosso used Ferrari in 2013, though.
Also, hi, first post!
Juzh
161
djos
113
Juzh wrote:I'll just leave it here:
http://www1.skysports.com/f1/news/12433 ... o-mercedes
100.
Pretty damming stuff!
"With a year’s worth of development it was expected that Renault could reduce that [40bhp] deficit, but the version of the engine delivered for Melbourne, which was expected to have 50bhp more than that used in Barcelona testing, actually had less power and much worse driveability,” Hughes wrote."
Hardly surprising then that red bull racing are furious.
toraabe
toraabe
raymondu999 wrote:
djos wrote:
Kingshark wrote:In 2014 the worst engine on the grid was Ferrari, this was highlighted by the fact that Toro Rosso comfortably destroyed Sauber, despite Sauber being clearly the superior team in previous years, and being faster than Toro Rosso so far this year (now that Ferrari have improved their PU significantly).
Fernando managed 2 podiums and a stack of top 5 results in the Ferrari.
The Renault engine managed even better
It had better top end power than the Renault, but lacked from low end tourqe, poor drivability, and a too rapid power curve. The Renault engine had much better drivability in 2014 than the Ferrari engine
toraabe
toraabe
100.
Renault can map the engine to create another 100 HP, but ..... it blows up.. Seems to be more a realibility issue .
I am sure they will sort it out.
FW17
169
So if all goes well then they will have 90 hp more than last year then will they have an engine as powerful as Merc?
2014
Merc -690 hp
Renault - 650 hp
2015
Merc - 740 hp
Renault - 650 + 40 + 50 -100
FoxHound
55
Thank you Jordan :D
In a messed up way it actually still makes my point! :lol:
JET set
raymondu999
djos wrote:you not agreeing with me doesn't mean my opinion is invalid.
And vice versa. It still doesn't change the fact that Renault outdid Ferrari as engine suppliers in every metric last year. Whether that was car or engine, we'll never know.
失败者找理由,成功者找方法
djos
113
True enuf, but not by much.
Phil
66
Nope. Debatable.
I think what may influence our perception of the Renault power unit has a lot to do with RedBull, the top team, struggling as much as it did. This gives the impression that the Renault engine was seriously bad. However, what played against RedBull in 2014 wasn't just the Renault engine in itself - it was also the fact that RedBull once again went to the extreme where packaging was concerned. I would say a lot of their struggles in 2014 were down to that alone and caused many reliability problems. When inside a less extremely packaged Lotus or Torro-Rosso, they worked better. Using the relative performance or WCC standings at the end of 2014 to deduct which of those two power-unit was better is difficult, because there a big differences in talent, finances and ability across the teams. If anything, I think both Renault and Ferrari were probably quite close to each other - and this wouldn't be all that surprising, since they both chose very similar set-ups in how they designed their engines. This tells me that they're output was probably also quite similar. It was only the Mercedes that went a different route with its intelligent design and therefore achieved very different cooling requirements.
#Team44 supporter
FoxHound
55
djos wrote:Hardly surprising then that red bull racing are furious.
What did they expect when they pushed Renault for parts that had seen no track time or even, quite unfathomably...bench time?
Shooting yourself in the foot comes to mind.
JET set
Juzh
161
Phil wrote:When inside a less extremely packaged Lotus or Torro-Rosso, they worked better.
This is a joke, right? Lotus and TR had maybe double the amount of failures last year compared to RB. TR was genuinely faster than RB only once (russia Q), but then got beat badly in the race, so their slick "williams like" car design approach didn't really work, did it?
Also, just so that people stop throwing the same nonsense around: Sainz finished ~1 minute behind ricciardo in melbourne this year.
