Barcelona In-Season Test 2016
Sasha
Sasha
63
Re: Barcelona In-Season Test 2016
PlatinumZealot wrote:
Sasha wrote:
davidfroshanzen wrote: how much of the increase hp ?
Everybody gets confused with this engine formula.It's not the hp you can get,it's the energy you can get from the fuel.(the PU with the higher efficiency wins) So pretty much look at the modern marine diesel power plants for clues.Every % better means more power from the limited flow and capacity.
You seem to be confused because at the end of the day the more power you can get out of every drop of fuel also means your engine's efficiency has increased.
It is not the hp. Honda ICE is between the MB and Ferrari in power but at that power setting,Honda would be 10kg of fuel short to finish the race.Also Honda can't make that power with full ER at the same time.
Canada updates for Honda is new fuel and mapping only.
matt_b
matt_b
Nico did both tests last season, its not a big deal, they both did more than enough in winter testing to know the car by now. Personally I think these tests should only be for the young/development/reserve drivers because they get little opportunity to drive these beasts. I'd be interested to hear Pascal comparing the Manor and Mercedes but i'm sure he will keep quiet.
That's very important note there ...So that means that shouldn't effect them under qualifying cause you don't need to ER during Quali?
No reliability updates in Canada?
Sasha
Sasha
63
Just better mapping(ICE and ERS) and new fuel.
OneAlex wrote:Without wishing to turn this into a Lewis/Nico thread, could this last minute switch be seen as a warning shot to the two drivers that there is a third Merc driver ready to replace them after Spain?
Hamilton won't be bothered; he doesn't like testing.
Vasconia
Neither Alonso. It seems that he had enough during 2001-2009 years haha.
davidfroshanzen
davidfroshanzen
Sasha wrote:Just better mapping(ICE and ERS) and new fuel.
how the results of the test turbine and ERS upgrades (no tokens) at the test after the race as you said?
superdowg316
So if the fuel flow limit went to 110kg instead of 105kg for next year, theoretically, McLaren Honda would be about 4th-8th (being generous) with the right aero and chassis but the same engine?
Friendship with Honda ended, Renault is my new (and more reliable) friend.
Andres125sx
That would mean no tokens used, but they´re claiming a token upgrade. Am I missing something here?
Vasconia
They dont know when the updated will be introduced. Firstly was Canada, now perhaps Austria. Who knows...
