rifrafs2kees wrote:Moanlower wrote:Helios wrote:Mercedes had to change the gearbox earlier today. Only took them 2 hours, that's not too bad. (Source: AMuS)
Thats quite a lot if you ask me. It often takes less to change a gearbox of a regular car.
I'm a mechanic and I would like to know how you change a gearbox in 2 hours on a regular car. You're way off...it's never done
bit of a long time ago but on my first car, a vauxhall viva HC, i got gearbox changes down to 32 mins at the end,
mind you i had am lot of practice, the gearshift extension tube on those was a press fit with a grub screw to help secure it, add in an enthusiastic teenager, low power and a stubbie lever with a really slick gearchange and i used to pull the shifts loose regularly, ended up with 2 boxes so i could swap them and repair gearchange without car being off road
different story today though, look at the time to change the clutch on the bloody mondeo when it came out
