Williams FW38 Mercedes
LookBackTime
LookBackTime
472
Re: Williams FW38 Mercedes
Andreas Haupt ‏@andihaupt1
#F1: @WilliamsRacing new frontwing for #BritishGP, #AMuS
BanMeToo
BanMeToo
Sevach wrote:
This looks like some serious equipment... anyone know about it? They are measuring tire/suspension deflection?
SameSame
SameSame
I assume those are high speed cameras directed at that green laser. If that's the case they are probably measuring tyre deflection under different loadings.
LookBackTime
LookBackTime
472
Williams investigates performance slump
http://en.f1i.com/news/64464-williams-i ... slump.html
LookBackTime
LookBackTime
472
From AMUS!
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Atticus
Atticus
Old rear wing - hopefully just for comparison.
Monkey seat is on as per maximum downforce.
The F1 Formbook - https://thef1formbook.wordpress.com/
Performance analysis of F1 race weekends based on raw official data
LookBackTime
LookBackTime
472
Bite-size tech: Williams FW38 wing mirror stalks
http://www.motorsport.com/f1/news/bite- ... ontent=www
By: Giorgio Piola, Technical Editor
Co-author: Matt Somerfield, Assistant Technical Editor
41 minutes ago
Williams has openly admitted it is struggling to improve the operating window of the FW38, as it is at sea in terms of understanding the tyres and adding downforce.
It completed extensive set-up and correlation work at the post-British GP test and hope to make improvements based on those findings in Hungary.
A new pair of wing mirror stalks have been introduced in Budapest that have a horizontal section that places the mirrors higher than their predecessors (inset).
Whilst the logical conclusion may be that they help the driver's field of vision you can expect they have further aerodynamic benefits.
Placing the mirrors up higher will put them out of the way of the aerodynamic devices on the leading edge of the sidepod, hopefully improving their efficiency and increase downforce.
flickerf1
flickerf1
Bad news. Williams have reverted to the China-spec bargeboards: https://twitter.com/albrodpul/status/756148077937983488
The Wicked + The Divine.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
As of FP1 Williams has kinda pressed reset on the car, last years nose, early season barge boards and rear wing.
LookBackTime
LookBackTime
472
Sevach wrote:As of FP1 Williams has kinda pressed reset on the car, last years nose, early season barge boards and rear wing.
I agree! One note: I think they have the new suspensions installed.
