A lot of "ordinary cars" lack a fuel return; returnless systems have been around for quite some time and can either use a fuel pressure regulator in the tank (in this case before the fuel flow meter) or use a on demand electric pump under control by the ECU.Dragonfly wrote:I have a question to the more knowledgeable.
I haven't seen and I don't know the internal design of an F1 car fuel system. But I assume they should have some kind of fuel recirculation, like on ordinary cars. Excess fuel from the feeder pump to the rail is returned back and one of the reasons is to prevent fuel getting too hot.
On the other hand the rules postulate that the fuel flow sensor is in the fuel tank. Up to now I thought the fuel sensor is somewhere after the high pressure pump.
If there is a return then how do they account for it?
Is the HP pump in the fuel tank too?
The high pressure pump is most likely a "flow on demand" piston type pump placed on the cam covers. The piston is actuated by a lobe on the camshaft, and the flow from the pump is controlled by a solenoid valve in the pump. The pump and its placement has been clearly visible on some of the engine photos released by the engine manufacturers and appear to be very similar to regular production units. On the Renault engine it seems to be driven by the intake camshafts, and there is one pump per bank.
The fuel pressure supplied to the high pressure pump is probably not more than a few bar.
No, you will not get exactly 0,01 cc of fuel every time from such an injector, and if you double the pulse to 2 ms you would most likely get more than twice the flow than at 1 ms.alexx_88 wrote:I'd love to see evidence of an ECU calculating the fuel flow over a short enough period of time to be considered instantaneous with an accuracy of 1% as is the one stated by Gill and without any correction factor programmed into it. It boils down to the question: if you put a 1ms pulse over a 10cc/second injector, do you get exactly 0.01cc of fuel each time?
What I bet is that, all the engine manufacturers have correction factors on the simple math that is SUM(injector_pulse_width * injector_size) which yield, for that engine a more accurate fuel rate value. The FIA needed the same measure tool for all, thus the the flow sensor. If every team gets 10 of them, tests them and uses the one which they like most (reads the lowest) then it's a level playing field.
For an injector to actually deliver it's full flow, the injector needle have to reach full lift, and the shorter the pulse, the less time spent at full lift. How fast the injector reach full lift will also vary.
Among some production diesels, the ECU is actually calibrated for the individual injectors used on the engine, just to give a good enough calculated of injected fuel mass and injector timing.
At higher loads you typically start the injection when the exhaust valve have closed, the fuel injection is then stopped at about BTC. So roughly 180 crankshaft degrees.langwadt wrote:It is direct injection so 1 ms is a long time, the whole compression stroke at 10krpm is 12ms
the flow through the injector will depend on the differential pressure, so will opening and closing times and it direct
injection so it isn't just fuel pressure vs. ~1bar like manifold injection it is fuel pressure vs. cylinder pressure
opening time will also depends on the voltage driving the injectors.
And I don't see why the teams, other than for the flow restriction, need an absolute flow flow number, they need
injections to be consistent so the engine can be tuned to the correct mixture
At lower loads you typically reduce fuel rail pressure.
I don't know if any of the current F1 engines have made use of stratified injection mode, but any such mode (and the corresponding late and short fuel injections) are limited to low loads and most likely lower speeds.
