J.A.W.
J.A.W.
109
wuzak wrote: Having the best available engine when it was needed most? The Hercules wasn't ready, and the earlier Bristol radials weren't suitable.
Not giving away their secrets (ie giving the supercharger designs to competitors)?
Meanwhile, Napier built a jewel of an engine that was, frankly, a bit player in WW2. It was too late, like the Griffon, to be built in large production numbers in shadow factories and under licence.
Napier also had help from the government. The government had some grinding machines diverted from Pratt and Whitney to Napier. The government forced Bristol to give up production secrets for the sleeve valves - secrets they had developed over 10+ years at enormous expense - to save the Sabre program.
Ok, about this bit, you do realize there was a 'war on'?
Of course the wartime expedients demanded such 'cooperation'..
But R-R were politically powerful enough to shrug it off..
None of Bristol's engines, (& fairly few of R-R's) could do anything to to stop the depredations of the Nazi FW 190 Jabo raids,
& the V1 cruise missiles crashing down on London.. unlike the Sabre..
..or go on to or spearhead the 2nd TAF post invasion both as A2G & A2A machines powering Typhoon & Tempest..
622
J.A.W. wrote:T-C, Honda research had shown that ultra-high rpm 4Ts were not particularly fuel sensitive,
& it was the 2T machines that suffered when leaded fuels were banned from GP racing.
The triple bank broad-arrow arrangement aero-mills such as the Napier Lion, did not suffer the 'herky-jerky' motion issues
that bedeviled the X-types, due to the 'magic' of the prime 3 at work, mayhaps?
what Honda showed over 50 years ago was that eg their 18000 rpm 50cc twin (bore around 40mm) only needed about 72 Octane
no apparent issue with lack of combustion speed
(it was widely stated then that Japanese machines could lose power on the higher of the UK Octanes due to slower combustion)
about 20 years ago faster-combusting fuels came to F1 (as engines designs required for their higher rpm)
availability of these fuels was an issue, they were denied eg to Le Mans etc and then denied at first to 4 stroke Moto GP
eg early RCE quantified a substantial shortfall from the expected power in one dual-use F1/endurance V12 from this cause (when at Le Mans)
the Lion etc has unequal motions - the stroke is less on the 2 banks that have slave-rods
the CRM (former I-F) W18 looks as if it has unstaggered banks so must be similar
their related 36 litre V12 gasoline job famously won powerboat races till banned (in the UK)
the gasoline 54 litre W18 was discontinued years ago, but the diesel W18 has quite recently been seen as outstanding
Rocchi designed and ran an equal rod 3 bank 500cc test unit at Ferrari
but then as I said, he designed and made complete 3 bank master/slave rod F1 engines for Life F1
and Harry Mundy designed a 3 bank F1 W12 (iirc unstaggered so master /slave)
also Guy Negre did a W12 design
http://www.motorsportmagazine.com/archi ... es-la-mode
EDIT now recalling HM favoured 3 banks to use 4-2-1 exhaust layout over V12 exhaust possibilities (need to check what 4-2-1 really does)
447
Tommy Cookers wrote: Rocchi designed and ran an equal rod 3 bank 500cc test unit at Ferrari
I wonder if a 4 bank engine, like the Cub, but with narrower angles between the outer banks, would have proved more useful?
That way either the intakes or exhausts could be between two banks, whereas a W12 required that the space between two of the banks had to share intake and exhaust.
J.A.W.
J.A.W.
109
manolis wrote:Hello Tommy Cookers
Thanks for the drawing:
http://www.pattakon.com/tempman/RollsRo ... er_rod.gif
showing the split of the master rod of the Rolls-Royce Vulture.
You write:
“fwiw I now think the Vulture piston motion had 3 geometries, eg for commonality of link rods and compression height ?”
If I understand the question correctly, the answer is: No.
The Vulture piston motion (and the Pennine piston motion) had 4 geometries.
The stroke of the “master piston” in the “top” cylinder and the stroke of the piston in the “bottom” cylinder were equal.
But the leaning angle of the slave connecting rod in the “bottom” cylinder was by far bigger than the leaning angle of the master rod, resulting in substantially different piston motion geometry and in substantially heavier thrust loads on the “bottom” cylinder liner and on the bottom piston skirt.
The two side pistons had common stroke which was substantially longer than the “master piston” stroke.
But the geometry of the two side pistons was not the same: the one side piston was performing a faster compression and a slower expansion relative to the other side piston. See the animations in earlier posts.
So, in total there were 4 different “piston motion geometries” (or 4 substantially different “piston motion profiles”) in the Vulture and in the Pennine engines...
Thanks
Manolis Pattakos
Thanks for the technical explanation of the fundamentally insurmountable flaws inherent in the R-R X-type engines, Manolis,
No wonder the Vulture crankcase 1/2s were fretting, as they sought to constrain such incoherent workings.
manolis
manolis
107
Hello J.A.W.
You write:
“You've got that about face, since for a N/A 4-stroke of the same displacement to even attempt at being competitive, it MUST be capable of operation at "really high revs".. ( & thus with "issues" of very expensively robust construction) - to come anywhere near2T outputs, power-wise.”
With the PatRoVa rotary valve there is no red line (rev limit) for the cylinder head.
In the last PatRoVa animations, while the design is quite conservative, the port area is bigger and the rhythm at which the ports open and close (actually the valve-time area the working medium “sees”) is faster than in the Honda B16A2 VTEC engine (1600cc, 4-cylinder,160PS at 7600rpm).
The 6.5cm2 port area of each combustion-chamber-port can easily increase at 10cm2 for racing applications. Can an 81mm 4-stroke cylinder make room for intake valves having similar flow capacity? They are required two intake valves of more than 40mm diameter each, it is required a significant clearance between them and between each of them and the cylinder liner.
The basic part of the PatRoVa rotary valve (the spool) is extremely robust and inflexible. Nothing to do with rotary valves like those of Cross (and Cross-Bishop), or like those of Aspin. The cooperating surfaces have the simplest shape: plane. The distance between the two side disks is small (30mm in the animation) decreasing the effect of the temperature difference of the two parts. All these make possible the efficient sealing even without sealing means.
Take the 4-stroke Ducati Panigale desmodromic 1199 Superleggera.
It makes some 170 PS per liter. With a shorter piston stroke (say 50mm instead of the current 60.8 ) and a red line at 15,000rpm (25m/sec mean piston speed) it would make 200PS per liter. And we talk for big cylinders (600cc each). But the desmodromic cylinder head falls apart at 15,000 rpm. For a PatRoVa with higher flow capacity than the desmodromic cylinder heads of Ducati, either 8,000rpm, or 12,500rpm, or 20,000 rpm (crankshaft revs) is the same.
Thanks
Manolis Pattakos
manolis
manolis
107
Hello Brian Coat
You write:
“common port - gas reversal/ gas exchange effects, residuals esp. part load, charge heating/detonation?
The common port in the PatRoVa rotaty is an advantageous characteristic.
The common chamber port associates each point of the combustion chamber equivalently with both, the intake process and with the exhaust process.
If it were necessary an independent exhaust port (as happens in the Coates spherical rotary valves) it would be a big issue: just imagine what happens into an exhaust spherical rotary valve.
The combustion chamber is compact and improves the scavenging during overlap, minimizing the residual gas.
As for the heating / detonation quality of the PatRoVa, the compressed gas sees no hot spots, at all, allowing substantially higher compression ratios than in a poopet valve engine and than in a rotary valve engine having independent intake and exhaust ports.
You also write:
“valve - coolant passage packaging, crevices/HCs, sealing/distortion?
In this photo:
the crankshaft has turned manually (i.e. the rpm are less than 300). The disks and the ports are dry and the manufacturing quality of the cooperating surfaces is not as required, nevertheless a conventional poppet valve is not doing better with the sealing of its valves.
With the required manufacturing accuracy and a DLC coating on the oppositely acting fronts and on the combustion chamber port lips, the reliability may be better than that of the poppet valves.
Depending on the application, the packaging can be from better to substantially better than the conventional poppet valve engines. See the size of the desmodromic cylinder heads of Panigale. With PatRoVa cylinder heads the flow capacity increases, the cylinder head red line doubles and the size / weight drops a lot.
Any leakage from the combustion chamber goes to the intake passageways into the cylinder head and recycles during the next cycle. This is also one advantageous characteristic of the PatRoVa rotary valve. Combined with the compact combustion chamber and the squeeze at the end of the compression, I can’t see a reason for more HC than in the best poppet valve engines.
The strength / inflexibility of the rotary valve can increase as required (a 60mm diameter hub bridging two thick disks each receiving a 600Kp (1,300lb, case of 100bar peak pressure into the combustion chamber) causes a less than tiny deformation / increase of clearance).
If necessary, a material like the INVAR can minimize or eliminate the thermal expansion.
And a coating with the proper DLC can protect the cooperating surfaces from wear.
When the leakage at, say, 300pm of a manual cranking (above photo) can be small, the leakage at 3,000rpm is ten times less (provided the same pressure is in the cylinder), the leakage at 6,000rpm is 20 times less and the leakage at 12,000rpm is 40 times less.
You also write:
“These are not "nails in the coffin" but they are "boxes to tick"?
The characteristics of the PatRoVa rotary valve are “game changing” and remove all the nails from the “coffin” of the rotary valves.
The poppet valve are good; they are the best solution so far; however, they have their own issues.
For instance, take the cylinder head of the Desmodromic Ducati Panigale 1299 (photo from cycleworld), one of the most advanced engines today:
and think about the roundness of the “valve seat” whereon the 47mm intake valve seats.
At one side the intake valve seat neighbors with the red-hot exhaust valve.
At the other side the intake valve seat neighbors with the other, relatively cold, intake valve.
And at the other sides, the intake valve seat neighbors with the relatively cold cylinder liner.
There are several reasons for being, the intake valve seat, not round.
Yet in practice it seems it works fine.
Thanks
Manolis Pattakos
J.A.W.
J.A.W.
109
manolis wrote:Hello J.A.W.
You write:
Thanks
Manolis Pattakos
Hi Manolis,
Current Moto GP engines are limited to 4 X 4T cylinders with a maximum bore of 80mm, whereas when
regulations were more open, but limited to 800cc, the Ducati desmo V4 was revving up to 19,000rpm.
Never-the less, no N/A 4T GP race engine has got near the reliable 440hp/Ltr that the final 2Ts made.
& even a showroom standard KTM 250 cc 2T MX makes an easy 50hp/8500 rpm at the wheel, for > 200hp/ltr..
Due to the inherent 4T power stroke working limitation, the torque available to such N/A engines MUST be
maintained to very high rpm, & this requires a robust/expensive construction with very short stroke to keep
piston speed within the bounds of durability/functionality.
If your rotary valve can demonstrate superior torque production at moderate rpm, that could be an advantage.
How would it respond to forced induction, such as turbocharging?
manolis
manolis
107
Hello J.A.W.
You write:
“How would it respond to forced induction, such as turbocharging?”
The characteristics and geometry of the PatRoVa rotary valve fit with supercharging more than any other valve train.
`This is because the total force acting on the PatRoVa is zero, and because it is “free” (it doesn’t need its bearing to stay in place), and because its friction remains zero (case without sealing means), and because the torque required to open the exhaust is not related with the pressure inside the cylinder.
In comparison, things get tough during the opening of an exhaust poppet valve of a heavily supercharged engine: during the opening of an exhaust poppet valve, the camshaft has to provide a force to the valve which equals to the force of the compressed restoring valve spring, plus the force acting on the exhaust valve due to the higher cylinder pressure, plus the force necessary to accelerate the exhaust valve. With a 36mm diameter exhaust valve (10cm2) and a cylinder pressure of 10bar just before the exhaust valve opening, a force of 100Kp (220lb) is added to the force of the compressed valve spring (which, typically, is substantially less than 50Kp/110lb in engines with normal rev limit, as most turbocharged engines).
Back to the PatRoVa: if necessary, the design can be slightly modified : a somewhat bigger diameter hub connects two thicker disks at the sides, to compensate for the heavier peak forces caused by the high pressure that acts, through the windows / ports of the combustion chamber, on the two side-disks. This is all.
As before, any leakage (say, during the warming up period) ends up into the intake passageways in the cylinder head and is recycled during the next suction cycle.
Thanks
Manolis Pattakos
Brian Coat
Brian Coat
99
Manolis,
Thank you for the detailed reply.
Very interesting.
It got me thinking and I probably need to think more!
Concerning residuals and detonation, what about the exhaust gas pushed into the exhaust/intake port, which does not have to be during overlap period does it, because the port itself 'overlaps'?
Concerning HCs, even if the leakage is good, would HC's get trapped in the large sealing crevice during compression and released on the exhaust stroke, like they do in the piston top land normally.
Concerning poppet valve sealing, they are a bit non-round when hot and sealing is helped by things like the flexibility of the valve, including the stem; plus a lot of force from gas pressure of course.
Zooming out, do we see that the need for high rpm to produce power is being reduced by the boosting trend?
manolis
manolis
107
Hello Brian Coat.
You write:
“It got me thinking and I probably need to think more!”
Please do keep thinking.
So far, only few people seem to understand how the PatRoVa operates.
You write:
“Concerning residuals and detonation, what about the exhaust gas pushed into the exhaust/intake port, which does not have to be during overlap period does it, because the port itself 'overlaps'?”
The intake port - exhaust port overlap at the “non combustion” TDC can be from small or zero to huge, as in the poppet valve engines.
In comparison to the poppet valve engines wherein an intake valve almost touches its neighbor exhaust valve providing a short-circuit between the intake and the exhaust through which the fresh charge from the intake valve opening escapes to the exhaust valve opening, in the PatRoVa the intake and exhaust openings are at a substantial distance, at the two ends of the combustion chamber, which is the ideal way for the scavenging of the combustion chamber. The incoming fresh charge pushes out the residual gas cleaning the cylinder.
For instance, take the cylinder head of the Ducati Panigale (photo in recent post) and think the overlap period. In the area between an intake valve and its neighboring exhaust valve it is formed a corridor / a passageway short-circuiting the intake and the exhaust ports: the fresh charge escapes to the exhaust (because it is the easiest / shortest way to follow the fresh charge), leaving the combustion chamber actually un-scavenged unless there is a lot of overlap.
According the previous, the PatRoVa needs substantially fewer (in crank degrees) overlap than a poppet valve engine and achieves a better (through) scavenging of the combustion chamber.
The “zero total force” the {atRoVa rotary valve undergoes makes easy the realization of a VVA wherein, depending on the operational conditions, the translation by a few mm of the bearings of the PatRoVa rotary valve varies the overlap and the duration, like:
With fewer residual gas in the combustion chamber (efficient / clean scavenging as explained above), with substantially higher compression ratio, without hot spots (like the exhaust poppet valves) into the combustion chamber, with a lot of squeeze just before the combustion, with a flat piston crown rid of valve pockets and with a compact combustion chamber with centrally located spark plug, the PatRoVa design seems way better than the poppet valve design as regards the detonation and the residual gas.
Regarding the compactness / smooth-shape of the combustion chamber, regarding also the travel of the flame, just follow the flame in the abovementioned Ducati Panigale to see what I mean.
Bore: 116mm, spark advance: 60 degrees(!), piston crown shape:
And talking for the Ducati Panigalle engine, one of the most advanced engines today, just think how many dozens of PatRoVa cylinder heads can be made at the cost of manufacturing one Panigale Desmodromic cylinder head.
By the way, has the Ducati a more “desmodromic” design than the PatRoVa?
You also write:
“Concerning HCs, even if the leakage is good, would HC's get trapped in the large sealing crevice during compression and released on the exhaust stroke, like they do in the piston top land normally.”
The volume of the “crevice” is tiny. Any leakage goes to the “intake plenum” and waits the next suction to re-enter the cylinder. Only near the end of the expansion a part of the leakage finds the way to the exhaust port of the rotary valve, but this leakage is already burned gas.
You also write:
“Concerning poppet valve sealing, they are a bit non-round when hot and sealing is helped by things like the flexibility of the valve, including the stem; plus a lot of force from gas pressure of course.”
On the other hand, and until the pressure in the cylinder to get high enough to deform the valve head or the valve seat in order to fit with each other (note: most of the compression happens in relatively low pressure, but high enough to cause leakage), a poppet valve seating on a “bit non-round” valve seat, cannot help leaking. And if it is an exhaust valve, any leakage goes to the exhaust unburned, polluting and decreasing the fuel efficiency.
Interesting: when a new design comes along (the PatRoVa in this case), the older designs (poppet valve engines, spherical rotary valves, Cross-Bishop rotary valves) get under the “microscope” once again.
You also write:
”Zooming out, do we see that the need for high rpm to produce power is being reduced by the boosting trend?”
A smaller engine has, among others, lower weight, less friction, lower cost etc. If it is a high revving supercharged engine, it can deliver lots of power when required, being fuel efficient and green etc when only a small fraction of its peak power is required.
A 1000cc turbocharged engine for medium size cars is a common solution today.
A 500cc high revving supercharged engine could be the solution of tomorrow: even lower emissions, even lower fuel consumption, even more power when required.
The PatRoVa design fits with heavy supercharging more than the poppet valve engines (previous post).
The PatRoVa design provides extreme flow efficiency.
The PatRoVa design fits with extreme revs (there is no rev limit for the cylinder head).
Isn’t the combination of boosting with high rpm a better “down-sizing”?
Thanks
Manolis Pattakos
J.A.W.
J.A.W.
109
Hi Manolis,
Toyota converted a supercharged 4T DOHC 4V engine to run as a 2T, but ran into poppet-valve top-end related problems..
If your rotary valve head is not sensitive to rpm running limits in the same way, then what about it functioning as an S/C'd 2T?
Here is some further Napier Deltic data of possible interest, including explanation of opposed piston/valve timing lead..
http://www.ptfnasty.com/ptfdelticoperation.htm
Brian Coat
Brian Coat
99
I thought about it some more.
Port layout/residuals: The effect I had in mind may be too small to be a concern.
Crevice HCs: it will happen but again maybe it's not a big effect. Model-able for sure.
(Poppet valves: HC leakage is nearly always insignificant even when the holes are distorted by heat.)
Your high rpm + boost suggestion. The power density and knock mitigation effects are attractive.
Time to get back to 2 strokes?
manolis
manolis
107
Hello J.A.W.
You write:
“If your rotary valve head is not sensitive to rpm running limits in the same way, then what about it functioning as an S/C'd 2T?”
The rev limit of a PatRoVa cylinder head is limited by the revs the underneath mechanism (crankshaft, connecting rod, piston casing) can operate reliably.
The PatRoVa rotary valve has higher flow capacity.
So, it can be used for supercharge 2-stroke engines.
The question is: would such an engine (2-stroke supercharged with PatRoVa rotary valve(s)) be better than a 4-stroke with PatRoVa rotary valves?
With a supercharger and valves (poppet valves or rotary valves) on its cylinder head, the 2-stroke engine losses its basic advantages (simplicity, low cost) and gets more complicated and expensive than the 4-stroke version:
A supercharged 2-stroke with PatRoVa cylinder head? It can be done. The question is: "Is the pain worth the gain?"
Thanks
Manolis Pattakos
manolis
manolis
107
Hello Brian Coat.
You write:
“Time to get back to 2 strokes?”
Back to 2-strokes, then.
Here is the arrangement / combination of two independent OPRE Tilting propulsion units (each with its own pair of counter-rotating propellers) for a Portable Flyer.
Here are the “internals” of each OPRE Tilting:
The two crankcases (actually the spaces inside the pistons) are not “pressurized”.
The scavenging can be regarded as “through scavenging” vertically to the cylinder axis (cross-through-scavenging).
Each OPRE Tilting driving its two propellers is perfectly balanced leaving the body of the pilot / rider rid of vibrations of any kind.
More at http://www.pattakon.com/pattakonFly.htm and http://www.pattakon.com/pattakonPatTol.htm and http://www.pattakon.com/pattakonTilting.htm
Thanks
Manolis Pattakos
J.A.W.
J.A.W.
109
You write:
Thanks
Manolis Pattakos
Hi Manolis, why would a supercharged 2T PatRoVa be any more "complicated & expensive " - than if built as a 4T?
If every piston down-stoke is a power-stroke, & the PatRoVa head can deliver the required gas flow, then 'what's not to like?'
