JohnsonsEvilTwin wrote: Would mercedes be legit as is? Now we know virgin and Williams were behind this, it will have a very realand unintended benefit on mercedes if that's the case.
All we have is a reporters claim. Do they say where they got their information from?JohnsonsEvilTwin wrote:
Andrew, baseless? Wild assumptions?
Auto motor und Sport.
The critical difference in both cases I believe is the primary purpose of the device.ecapox wrote:let me understand this:
A driver lifting off the pedal which the computer compensates and automatically applies a certain throttle percentage for "blow through" exhaust. Illegal. Moveable aero.
A driver putting the back of his hand against a hole to modify the flow of air and direct it over the rear wing to stall it. Legal. NOT moveable aero.
Makes no sense.
You just said that both are for modifying the aerodynamics, although one is potentially illegal while the other was a-ok.beelsebob wrote: The critical difference in both cases I believe is the primary purpose of the device.
When a driver puts his hand over a hole to block flow, the primary purpose is to modify the aerodynamics.
When an engine map blows air through the exhaust without driving the car forwards, the primary purpose is to modify the aerodynamics.
On the contrary, both are on the illegal side of the line (at least that's what whiting is saying) – it's just taking a bit of clarifying to convince everyone.ecapox wrote:You just said that both are for modifying the aerodynamics, although one is potentially illegal while the other was a-ok.beelsebob wrote: The critical difference in both cases I believe is the primary purpose of the device.
I think there is no doubt now."We learned yesterday evening that it was Williams who wanted clarification, strange as they run an EBD themselves"
