CaterhamF1 CT-01 Renault
Scania
Scania
Re: CaterhamF1 CT-01 Renault
nacho
nacho
Looks to have rake. The rear of the car looks very long and empty,
N12ck
Wow I've just realised something, do you not think the Caterham/ Team Lotus Livery is inspired by the Minardi?
Look :
8)
Budding F1 Engineer
RB7ate9
RB7ate9
I just hope they add some more sponsors or decals or SOMETHING. Having an empty mid-section and a big yellow decal makes the poor thing look chunkier than it really is.
DCren
ringo wrote:
Caterhamrules wrote:The 2012 Caterham F1 car testing at Jerez
car actually looks composed. Big improvement over the 2011 and 2010 car.
I was watching the hands in the turns. No quick adjustments, very little movement if at all. Way different than last year. Very stable in that video at least. Could be a bad thing thou. Tight is slow, loose is fast.
“It's not something that happens overnight. I kept saying that until mathematically things are impossible, I will keep fighting,” Michael Schumacher.
MIKEY_!
Slow is smooth but smooth is fast.
raymondu999
Or he could have been coasting below the limit of grip - when it would be easy to be slow. Or maybe the drivers have just changed to a smooth style :lol:
失败者找理由,成功者找方法
Pierce89
N12ck wrote:Wow I've just realised something, do you not think the Caterham/ Team Lotus Livery is inspired by the Minardi?
Look :
[img]http://minardi.sweb.cz/Picture/MinardiM191B.jpg[img]
[img]http://farm8.staticflickr.com/7027/6849 ... _z.jpg[img]
8)
I believe it's supposedly inspired by the mid 60's Lotus colors
Reason: Removed quoted image from post above
MIKEY_!
Only the nose stripe and individual colours. The back of that minardi is a perfect match.
DCren
raymondu999 wrote:Or he could have been coasting below the limit of grip - when it would be easy to be slow. Or maybe the drivers have just changed to a smooth style :lol:
This is all true. I also watched the Caterham video on GP Update. Here's the link.http://www.gpupdate.net/en/videos/1874/ ... -in-jerez/
I could be partial too. I always liked Mikes' no BS approach.
raymondu999
I'm not sure what you're trying to point out from that video, sorry? :?
失败者找理由,成功者找方法
Leon
Leon
16
Interesting,why there four pylons(supports) instead of two? What benefit from them?
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
MIKEY_!
The two at the back smooth airflow around the base of the airbox as well as being part of the roll structure. That allows the undercut to be bigger. The front two are to create the hole for the car to be lifted off the track after an accident (I wouldn't rule out them being part of the roll structure as well)
Edit: mclaren were first to do it back in 2008 I think
scarbs
scarbs
393
Its the metal inner strcuture of the roll hoop. Similar to that below, there's four legs as the structure is more heavily undercut and hence gives a better flow to the rear wing.
Owen.C93
Owen.C93
172
scarbs wrote:Its the metal inner strcuture of the roll hoop. Similar to that below, there's four legs as the structure is more heavily undercut and hence gives a better flow to the rear wing.
[img]http://twitpic.com/show/thumb/8q6oaj.jpg[img]
Are all 4 structural on the Caterham then?
Reason: Removed image quoted from post above
