Sauber C31 Ferrari
beelsebob
beelsebob
85
Re: Sauber C31 Ferrari
I don't see where you guys are seeing a vent – can you highlight it?
sesku
sesku
is that vent look like this? sorry, rough sketch.
This letter is computer-generated ; no signature is required.
horse
There is no hole in the nose tip so it could be an alternative inlet for driver comfort???
EDIT: Or outlet, even? If you can circulate some air through the cockpit, you'll make a little downforce...
myurr
myurr
beelsebob wrote:I don't see where you guys are seeing a vent – can you highlight it?
I'm not sure it is a vent - it probably isn't - but there is something different going on with that nose. Stefan and sesku have highlighted what we're looking at. Explanations on a postcard please :)
Agerasia
Agerasia
Possibly a blown front wing.
"badically pressuring rosnerg " Ringo 05/10/2014
horse
Possibly something like this, huh?
(Thanks to Gusgus for the original drawing)
FrukostScones
162
I think they blow the kink to reduce its drag. Blown platypus nose whatever.
n_anirudh
n_anirudh
W wing for Sauber
Multi-element for the diffuser central area and brake vents
raymondu999
失败者找理由,成功者找方法
hollowBallistix
hollowBallistix
From what I can gather there is no vent/hole in the nose cone, it just was a dip / recess just behind the ugly transition, something like this :
Shot at 2012-02-06
Bazza
Bazza
n_anirudh wrote:Image
W wing for Sauber
Hang on, what's going on under that diffuser? The two roundish things just off-centre?
gibells
gibells
A Blown Nose? Bless You Sauber. Kleenex Sponsorship anyone?
Oneshortplanck
Oneshortplanck
my money is on it being some sort of hidden front wing,
air scooped from under the platypus nose, and exits on top surface.
Do not argue with an idiot. She will drag you down to her level and beat you with experience.
Gusgus
Gusgus
Oneshortplanck wrote:my money is on it being some sort of hidden front wing,
You can't have that since 2009, no hole permitted in the nose area apart from one at the tip for driver cooling.
