The speed will be at least as fast as the so called 'seamless' shift systems.richard_leeds wrote:autogyro - how quickly can a human physically move a shift stick between gears on a manual box? Assuming the clutch isn't used.
The absolute speed is dictated by the capability of the engine to reduce rpm during the shift.
This (even with light F1 rotating components) will always take longer that the time it takes to move one gear out of full engagement and another one into full engagement.
A racing gearchange using a dog ring manual gearshift is undertaken with NO lifting of the throttle. One dog ring is disengaged and the next gear dog ring engaged in exactly the time needed to match the (unchangeable) engine rpm decay time between gears.
A modern so called 'seamless' gearbox can only match this or reduce the torque transfer from input to output if its shift components are partialy engaged before the engine rpm establishes at the shift completion point.
