Question about suspension linking.
NOS_ATX
NOS_ATX
Image(http://d.pr/PQii)
This is a rear suspension system of a F1 car
In red circles we may find that the arms are linked to the body by ball joints.
Image(http://d.pr/bVmL)
Why the Teams use ball joints instead of normal cylinder joints?
Also in this picture, I can't explain how the arm rotate because there is no any joint between the arm and body.
Image(http://d.pr/a4rZ)
Anyone can help me? Thanks! :?:
Reason: removed bold font
Caito
Caito
Re: Question about suspension linking.
The "cylinder joints" you're referring to I think are rubber bushings.
Rubber bushings have too much compliance for an F1 car so they use spherical bearings.
These allow for a spherical movement without compliance.
The ones in the last pictures are flexures bearings. They work by bending a load element(wikipedia).
http://en.wikipedia.org/wiki/Flexure_bearing
You can find lots of information in the forum using the search function.
BTW, welcome to the forum, you can leave some greetings in the new user thread.
Caito.-
Come back 747, we miss you!!
