West wrote:I can understand less mass equals less inertia, such that it is easier to change direction. But given a force, doesn't less mass mean that the piston will have a higher acceleration (and then higher velocity?)
True, if the piston was allowed to be accelerated by the forces of combustion expansion. But the piston is connected to the rods, crank, etc.
When I was describing piston acceleration, it was in reference against another piston that had a different stroke.
In fact, don't even consider the combustion process, just imagine that a crankshaft is being turned by external forces, the pistons are enjoying a free ride. Starting at top dead center, the piston begins accelerating downwards, to pass the mid-point of the stroke, then begins to decelerate as it reaches bottom. Then it begins it's path upwards, going through acceleration forces, again. If you ask the piston to keep the same RPM, but travel further each stroke, it undergoes higher acceleration forces than the previous shorter stroke. And that's what it's all about, that a shorter stroke has lower acceleration than a long stroke, and thus, less mechanical loads.
